MP402spf
  • tcypy1961
    • 773
    [Jamming] MP402spf
    Thinking of replacing some of my rental machines with these. Are they reliable that is not prone to misfeeds/jamming???
    Thanks!!!!
    • 37062
    Re: MP402spf
    Just remember that they are an entry level machine.
    • KeviM
      • Oct 2019
      • 324
      Re: MP402spf
      I'm interested in what the other techs / engineers have to say about this as well.
      My company might be considering putting a few on the field as well.
      From what I've researched the spares seem a bit pricey and also a bit difficult to get
      • anothertech
        • 1757
        Re: MP402spf
        They are great machines if run at or below recommended volumes. Ricoh made a lot of improvements with the machine through new firmware, so if you get some in, update the firmware before they go out in the field.
        • MIKON
          • Jul 2015
          • 186
          Re: MP402spf
          It's a good box plan on replacing the drum every 40K..........
          • emiliorsg
            • Jul 2018
            • 141
            Re: MP402spf
            Good equipment, with a good engine, the maintenance cycles are correct, but it is a bit expensive since it is an entry-level range, as slim says
            • TonerMunkeh
              Professional Moron
              • 3865
              Re: MP402spf
              Meh, they're alright. Keep them well away from any customers I like to refer to as "knuckle draggers". They don't do well in that sort of environment.
              Hit it.
              • aktasson
                • Feb 2017
                • 201
                Re: MP402spf
                Thanks!!!!
                First of all same as it ever was... it depends on your location, usugae profil, (paper)quality and behaviour (of user) . The toner replacement is a litle bit tricky but tradable. The adf is sensitive during paper feed entrace for folded paperdocuments. On the whole in my opinion a nice compact bw machine.
                  • 8121
                  Re: MP402spf
                  Thanks!!!!
                  So far no real issues. Reliability wise similar to the MP 301, PCU life only around 40k.
                  • luca72
                    • Oct 2017
                    • 1711
                    Re: MP402spf
                    Thanks!!!!
                    we have a few around, it generally works well, personally the only things I have encountered are, it has the pcdu a little weak, and the rdf hinges tend to unscrew, but nothing serious if you know it
