Ricoh Pro C5110 SC682-12
  • bat
    • Sep 2008
    • 140
    The technician tried to install Engine, Network Support, Web Support firmware, System/Copy firmware was not installed. probably should have installed System i Engine as a set. So now the machine is stuck with SC682-12. Tried to replace the Cyan PCDU, no luck, I tried all the resets I could think of. Still the same. Any ideas?
  • dalewb74
    • Feb 2018
    • 1153
    Re: Ricoh Pro C5110 SC682-12
    have you tried just the package all firmware, instead of individual?
    • bat
      • Sep 2008
      • 140
      After SC682-12 i instaled the whole package, latest firmware., still no luck.
        • 37494
        SC682-12 is a communication error between the mainframe and the CYAN toner bottle, not the PCDU. Usually a bad chip on the bottle though it could be a bad connection to the bottle. Try re-seating the the toner bottle or installing a new bottle.
        • bat
          • Sep 2008
          • 140
          The definition is referring to PCU.
          SC682-12 PCU: ID Chip Communication Error(C_Device Error (No ID chip))
          I have replaced toner cartrige and PCDU. This was a working machine, the error accured after firmware update.
          • anothertech
            • 1770
            Downgrade the firmware to what it was. Check the seating of the toner hopper and the drawer unit closely.
            • Dev
              • Mar 2014
              • 13
              Hello.First sorry my english.
              Can you tray to replace black pdcu instead cyan?. I dont remember exactly, but I think I had this code in this machine some years ago and reading the service manual of another Ricoh model this code would refered to black pdcu. Anyway,good luck.
              • bat
                • Sep 2008
                • 140
                Thread update, downgrading firmware didn't work. All PCDU are tested on other machine and working fine. So problem is narrowed to boards, most likely controller...
