Firmware update error 86
  • romang
    • Aug 2011
    • 72
    • 37532
    Re: Firmware update error 86
    One of the huge drawbacks to using package firmware and the firmware update tool. You may need to contact Ricoh support desk in order to get that file.
    • dalewb74
      • Feb 2018
      • 1156
      yeah package all is the firmware.....
      • GIUBOSS
        • 1436
        Which method are you using, rfut ?
        • romang
          • Aug 2011
          • 72
          I tried updating with sd card and rfu, same error e86 when it gets to end. It looks like it has special firmware for network and web support. I will try Ricoh support.
          • sandmanmac
            • 3981
            The only way I've overwritten machines with custom f/w is to update using the romdata files (.fwu)
            This always works.
            Once the custom f/w is overwritten, the other methods will work going forward.
            • romang
              • Aug 2011
              • 72
              I didnt see any individual files only the package, thanks
                • 37532
                What model and where are you looking?
                • sandmanmac
                  • 3981
                  Huh? and "Where?" (as Slim asked)
                  It's literally been the most common way to update F/W..... forever! (manually at least)
                  • copier tech
                    • 8172
                    In his post he states the issue is with the 5x
                    IM 550f models he purchased.
                    There is both romdata files or the package file available for this model so try updating the modules of system / copy then try the .pkg file again.
                    • anothertech
                      • 1771
                      The .fwu files are compressed inside the package. Download easy 7zip and extract them.
                      • romang
                        • Aug 2011
                        • 72
                        Thanks , I will try that next time in shop.
                        • dalewb74
                          • Feb 2018
                          • 1156
                          are you positive you are downloading for the correct model? i have had it happen, i didn't have the exact model. then i realize what i did.
                          • romang
                            • Aug 2011
                            • 72
                            Yes, I have other techs at our shop working on it too , in fact one of them started working on it first.
                            • romang
                              • Aug 2011
                              • 72
                              Thanks for all the help, I was able to extract the individual files and update the machine then did the package just to make sure and its all updated. Thanks another tech!
