ANYONE HERE rebuilding the fuser sleeves on mpc3003-mpc4503?
  • fshead
    • 2376
    greetings i have a bunch of oem bad fuser sleeve assemblies that i want to rebuild.
    I bought a few chinese sleeves only and fuser felts with grease"more like oil".
    but results were not great.i am now looking for japan made or japan quality only and i hate tearing them apart and getting
    little yield so i figured id ask here.
    I buy from the one big site for chinese goods..
    thanks in advance
  • MIGUELMARCHENA
    • Feb 2018
    • 195
    Re: ANYONE HERE rebuilding the fuser sleeves on mpc3003-mpc4503?
    I have used some from aliexpres "high durability"..for now they go with 60,000 but sometimes they have been damaged by hooks etc.
    Since it is with oil, you have to lubricate it every 50,000 times because it dries out and creates jams.
    Before doing the maintenance you have to have a medium broomstick and stick some foam on the diameter so that you can clean the case internally because the oil solidifies with the toner that manages to enter...be careful with the amount that is added. damages the lamp.
    ...... fill the syringe again to oil the plush.
    or if you have the right fat, great
    • fshead
      • 2376
      THANKS
      I REUSE THE OIL FELT IF THERE IS NO DAMAGE AND IF THEY ARE STILL SOFT..
      NOT SURE ABOUT THE BROOMSTICK..I HAVE REDONE THE CLOTH FELT,,A REAL PITA to remove all the tiny screws...
      i am use the high temp grease from the old HP 4200/HP4300 SERIES PRINTERS..
      SEEMS LIKE RICOH STILL CANT FIGURE OUT SLEEVES AS I HAVE HAD MPC3404EX FUSERS FAIL EARLY WITH SAME ISSUES..
      I MISS THE OLD ORANGE FUSER ROLLERS FROM THE PAST...
      • emiliorsg
        • Jul 2018
        • 141
        I have rebuilt several with different results, always when the felt is good. Many times they have worked well, giving a result of about 100k, but other times they have given cold offset from the first copies.
        • luca72
          • Oct 2017
          • 1784
          thanks in advance
          I have rebuilt several, and so far I haven't had any problems, I usually change the external sleeve, the pressure roller, and the thermistors, and I put a lot of oil with a syringe, in several stages, maybe 4 or 5, first I put a little, then I wait for it to absorb, and then I add more, I repeat this loop until it is visually visible
          saturated, if the fabric strip is damaged I throw it away and change the complete heater, for now I have done: mpc2003, 3003, 6003, 2554, and 4054, and others that I don't remember... I have to be honest, my favorite is the one from mp4054 series, I have a lot of fun!
          "I'll be back"
          • Gift
            • Mar 2011
            • 2459
            Tried it once but I had a hard time with that 3D puzzle and finally made a mistake and damage the sleeve - got angry and tossed everything in the bin LOL
            Older sleeve units are easier to disassemlbe/reassemble - like the MPC2051 for lubication against tortured seal noises.
            • copier tech
              • 8172
              Simply not worth the bother when the genuine Ricoh sleeve does around 400k +
              • fshead
                • 2376
                i have yet to see a 03 fuser hit 300k nevermind 400k and this is regular non arty or print heavy applications..
                I do not know if they will still work and not code out or other issues if you remove the moving heat plate that pivets on both sides..
                that one is a bit of a pain to align ang get everything closed up..
                give me a teflon roller anyday b4 this crap..
                i will chime in that the felt does NOT suck up the oil easily..
                i never use all the oil as it would get on lamp..maybe pre heat them with hair dryer first and see..
                  • 37532
                  I never had a fusing unit fail before 400K unless due to damage to the sleeve by improper clearing of paper jams, rings with large stones can be hard on sleeves and ITB. I have had lamps fail if you try to push them too far. The complete sleeve unit includes new lamps. An after market sleeve doesn't.
                  • anothertech
                    • 1771
                    I always go reset the fuser message when it pops up at 400k, then let it run another couple 100k
                    It's kinda funny that you don't get the same life out of them.
                    • mikadonovan
                      • May 2008
                      • 2931
                      Me too.
                      NEVER ASSUME ANYTHING
                      • Popolopo
                        • May 2023
                        • 136
                        The issue with those OEM part, sometimes it causing toner not stick.
                        Need to increase temperature to fix that.
                        But that create new problem, where the paper will curl when exit.
                        • copier tech
                          • 8172
                          Yes, we get calls all the time for "replace fuser sleeve" if the print quality is still good & the sleeve visually looks good we simply reset the PM count.
                          • fshead
                            • 2376
                            hmmmmmmmmm..
                            must be this dirty nyc air....i had the same experience with the 02 series too,luckily i did not sell lots of them as the 03s became available..
