Hey Folks... Working on MP 4055, Has a Fuser Error... Putting in known good fuser with new Pico fuse plugged into the connector where the blue loop is... Trying to do Hard reset, 5810 #2... Fails all the time! Tried 2 different good fusers...Same...Thanks for any feedback...Haven't done this before...Hope I'm doing it right...The color Machines work all the time with that Pico fuse with the white connector on it... This one driving me crazzzy! Appreciate your help, Laser801
MP 4055 Wont "Hard Reset" Fuser Error
Re: MP 4055 Wont "Hard Reset" Fuser Error
Hey Folks... Working on MP 4055, Has a Fuser Error... Putting in known good fuser with new Pico fuse plugged into the connector where the blue loop is... Trying to do Hard reset, 5810 #2... Fails all the time! Tried 2 different good fusers...Same...Thanks for any feedback...Haven't done this before...Hope I'm doing it right...The color Machines work all the time with that Pico fuse with the white connector on it... This one driving me crazzzy! Appreciate your help, Laser801Comment
Thanks for your response...Well, We have actually been trying this "Known good" Fuser unit with the "Good" Pico Fuse on three different units... One had an SC545...One had an SC554...and the third had an SC 561... I can put this Fuser unit into a working machine and it's fine...I pulled the fuse out and there was continuity... Am I missing something here??? I have done this once before and it worked a while back...For some reason it won't complete the 5810 #2.... The fuse does go where the blue loop is, Correct??? Is there a certain sequence in the reset that should be followed... Going crazzzzy here! Did the 3701 New Fuser as well... HELP !! before I go back to servicing Typewriters !!!Comment
Sorry... I replied in length down below... I respect your thoughts on this...Comment
You need to fit a NEW fuse, if you are taking a 'known good fuser' the fuse would already have blown.
​Comment
The fuse doesn't go where "the loop is"
PICO Fuse.pdfComment
Hey Folks... Working on MP 4055, Has a Fuser Error... Putting in known good fuser with new Pico fuse plugged into the connector where the blue loop is... Trying to do Hard reset, 5810 #2... Fails all the time! Tried 2 different good fusers...Same...Thanks for any feedback...Haven't done this before...Hope I'm doing it right...The color Machines work all the time with that Pico fuse with the white connector on it... This one driving me crazzzy! Appreciate your help, Laser801"I'll be back"Comment
Playing with a machine with a SC545 now... Going to try putting fuse in different location...Thankyou!Comment
