RIcoh MP 402 ADF bending originals in corners and prints are cut off on the left
  • patterson70
    • May 2010
    • 601
    Hello, I went on a MP 402 call yesterday and there are two problems:
    1. The ADF is bending the originals in both of the leading edge corners. Please see the picture attached. You can actually see the ADF pop up a little as the original is going through as it bends the corners. I pushed a light cardboard sheet through a few times but nothing is coming out. If I press down hard on the ADF as it is copying the original will not bend. So something is not right. I am thinking someone damaged it somehow and something inside is bent, but I can't see anything wrong. Any ideas?
    2. When I print the counter sheet it is missing the left image a little. For example the word "Serial" has the "S" and part of the "e" missing. It has nothing to do with ADF of course. How can this happen, and ideas on this?
    The machine is in a church with a school for little kids. I am wondering if one of these kids got to the machine and messed it up....
  • luca72
    • Oct 2017
    • 1784
    Re: RIcoh MP 402 ADF bending originals in corners and prints are cut off on the left
    TOH...get this!
    "I'll be back"
    • anothertech
      • 1771
      Originally posted by luca72
      TOH...get this!
      Yes it sounds like that hinge is broken. I've done a few of those mods, works good.
      Problem 2 is a dirty LED array that sits on top of the drum, clean the LED, replace the drum if the problem returns.
      • patterson70
        • May 2010
        • 601
        TOH...get this!
        Much appreciated. I will go out tomorrow to look at this hinge.
        • patterson70
          • May 2010
          • 601
          Thank you as well. I will check this out tomorrow and report back soon.
