Ricoh 2045e fuser jams
  • Rick
    • Mar 2007
    • 277
    I have a few of these machines that are drivinf me nuts. I replace all of the fuser parts and still acordian jams. Are there any mods tips or secrets to keeping these fuser units running ok ?
  • spaceman99
    • Jul 2009
    • 174
    replace entrance guide and remove cleaning roller. If this fails the likely cause will be the reg guide plate. replace guide plate and reg and relay clutch.
    what jam codes do you have ?????????? if you have exit jams then it will be guide plate.
    good luck
    • oswaldo160
      • Oct 2008
      • 69
      good luck
      Yeah..
      You have the reason.
      But also you can clean the cleaning roller.
      • Black Cloud
        • 145
        Also check the lead edge void.
        Net+ PDI+ @Remote
        • Rick
          • Mar 2007
          • 277
          I put new cleaning rollers on every time I rebuild and new pick off fingers . I changed the lead edge void to 4 mm also.
          • zed255
            How'd ya manage that?
            • 1024
            Are you sure its a fuser jam, or just what the client is reporting? Could the interchange gates be sticking and at least some of the jamming be occurring there? I've had several situations where the client insists the fuser jams to later find the damper pads in the interchange were sticky and in need of removal.
            • bostjanma
              On the fuser you have small groove in the midle for paper fusing exit senzor witch is located in right hand door (transfer unit). Clean senzor and and groove where the sensor beam rebound. (on the fuser unit). There is a paper dust!
              by
              • tcs04
                FORMER Techie
                • 1183
                by
                AND check this sensor has a red end. If white it's one of the old ones which used to fail. I think they were all red on the 2045.
