This should be easy for you ricoh guys. Can't find copy quality adjustment on aficio 2075. The one on display & in user mode don't seem to do anything. It's light especially on solid blacks. Help.
Ricoh Aficio 2075 - PCQ
sir have you check the consumables? perhaps you need to replace it! opc, developer, charge corona, transfer check those stuff may problem comes there.fix the customer first then fix the machine... its simple and makes life more easy. -
B064 9640 Developer
AA01 2060 Dev Filter
That could be the most likely source of your problem
Also if it's fitted with an A295 9510 drum then that only has a life of 350K, The newer drum also used in the Bellini C2 B070 9510 has a life of 700k.
Also:-
Charge Corona Wire:- B070 2364
Grid:- A096 2060
Pads:- A096 2063Comment
oldcopyguy
It used to be that no contrast adjustment was due to no / poor bias connection. Check the continuity betweeen the front of the mag rollers and the bias connection to the power pack. If thats ok, check the bias at the front of the mag roller and also the continuty between the dev casing and frame.
There used to be a fault where the dev casing shorted to the frame and dropped the bias (the dev frame is charged to prevent dev scatter), there should be some insulation at the front of the frame. Try sliding a couple of sheets of paper between the bottom of the dev unit and the frame as a temp insulator. If this works insulate the frame with tape.Comment
Copy Face up or Down
Hi,
Check out the following,
Regards
USER TOOLSEject Copy Face Up/Down in Glass Mode
Eject Copy Face Up/Down in Bypass ModeComment
shortly i meant, i can flip the paper face up and down in the glass copy, i can flip the paper face up and down in the bypass copy but whenever i try to use the SADF copy mode i got the copy product only one type, the copied face is down, i can not change mode to that copied face up in ADF copying. since machine's digital menu is German, i can not understand how to adjust that option. please help..Last edited by can06; 06-18-2009, 09:41 AM.RICOH Pro C900sComment
