arm-450n first tray copy issue
+ More Options
Posts
  • DINGO
    • 661
    Hello
    I'm here again to bother you with a new problem in a arm-450n, and because i have difficulty to explain to me in english i post the issue in attachements.
    -only hapenned of the first tray, n the others tray everything ok.
    In advance i post what i already do:
    -I chek and replace every three rollers, and including to, a new spring pressure of the reverse roller.
    -Ichek the black plastic in the left door, ( that press the guide of the first tray).
    -I make a copy whith the left door open, and the paper finds no bar, pass ok
    Can somebody give me any idea what be be more?
    thanks in advance
  • spotlifter
    • Mar 2008
    • 65
    What happens if you try print? Does it have same issue as copying?
    Cause I'm seeing you are copying from scanner.
    I had some problem same as your 1st tray but it is jamming every 2nd paper. When I do duplex, no jamming, only 1 sided copy will jammed. What I did was : -
    Removed the main drive box and serviced the 1st tray clutches.
    (Hard work here, while I'm there I serviced all the clutches as well.)
    I'm not sure my image was shifting. Try sim50-12?
    sigpic
    • DINGO
      • 661
      re
      ok
      Was what i started doing, just leave the question in the forum.
      Tomorrow i finish, and then say something.
      About your question, yes the issue is the some in print, make sense a service at first tray clucht, very very hard work.
      thanks friend.
        • 22997
        "99" is a bit too high for tray #1 buckle in 51-2. Try a setting of "85" before continuing with your troubleshooting. =^..^=
        • DINGO
          • 661
          re
          Hello good friends.
          Today , i finish the main drive service, ( gears, clutches and so) and now evrything ok, the 51-2 was now in value normal.
          good night
