sharp ar-286 H5-01 error code HELP???
  • nolovenodie
    Hi,
    Please help.....I think it's a fuser jam error......I cleared the jams already but still have that "Call for service" message.
  • johnbla
    • Apr 2005
    • 94
    H5-01 is 5 continuous jams in the F-section and requires full examination of F-section and Left door assembly, for root cause.
    It will need Engr/Sim codes to re-set the machine.
    regards
    John
    sigpic
    " The Game never ends..When your whole World depends..On the Turn of a Friendly Card..."
    • nolovenodie
      I'm sorry...i'm really new to this and dont even know where is the F-section. What are the Engr/sim codes to reset?
      • nightshade
        Chromographic Supremesist
        • 158
        F-Section. Means the fusing section.
        The service code H5-01 needs to be reset by a technician. So you may wish to call your local Sharp authorized service supplier.
        • trench
          reset code for h5-01
          I don't know if this will work for your model but on a sharp mx-2700n
          pressing #p * c * then 14 execute press blk/wht button then press CA will reset a code h5-01. I had a bad paper jam in the fuser that set the code.
          • johnbla
            • Apr 2005
            • 94
            What is the point in just 'Re Setting' an Error code, If you don't know WHAT it means and WHAT happened to cause the Error code in the First place.................... ???
            Ps
            MX code won't work on a Cougar
            regards
            John
            sigpic
            • nolovenodie
              Ps
              I guess it's just to "temporarily" solve the problem and wait til I have the money to fix the machine. :-)
              • JDE75
                • Apr 2007
                • 24
                P * C * 14 Then 1 For Yes And Follow On Screen Directions, Code Should Clear Out.
                Jamie
                • videohockey
                  Jamie
                  I tried this to clear my H5-01 error on my AR-286, but nothing works.
                  To clarify:
                  P is the Program button
                  C is the Clear button
                  Is there a button for the * or is that just a separator for button hits?
                  Thanks!
                    • 22927
                    Maybe you should find out why it jams every time? A reset is only indicated here when you solve your jamming problem. For example, Is there a lead edge void on prints? No void means heat roller wraps every time. Broken or out of position pawls? Teflon worn off the heat roller? Is gear 48T melted and/or deformed due to overheating? Is the bed handle broken by rough handling by the customer? Does the exposure lamp light too slowly, causing a black leading edge on every copy? Is paper wrapped around the rollers or the lower roller impaled by a fuser pawl, stopping rotation?
                    And that is just the common causes. =^..^=
                    • videohockey
                      It goes into error when I attempt double-sided copies only.
                      I had a tech out last year and it still failed. He thought it was an expensive fix to do double-sides.
                      I just need it now for single-sided copies.
                      • bilyahn
                        • Dec 2006
                        • 1467
                        What have you replaced to fix the original problem? What are the jam codes now?
                        • Akitu
                          Legendary Frost Spec Tech
                          • Oct 2010
                          • 2595
                          Epic thread necro, 2007. +1
                          No, this comment was not meant to contribute anything, and I haven't seen an AR-286 ever.
                          • videohockey
                            I do not know what the tech replaced. It was over 1 year ago.
                            The only error code displayed is H5-01. There does not appear to be a paper jam anywhere in the unit.
                            • bilyahn
                              • Dec 2006
                              • 1467
                              Have you tried using the other tray? Seems like from what you are saying it is a paper feed issue out of the tray. Jam code would help a lot.
