AR 207 top of the page faded
  • Ricoh Dicoh
    • Dec 2010
    • 62
    What could cause the top of the page to be faded/light copy
  • bdcrandall13
    • Sep 2010
    • 236
    Most likely developer or the Laser slit glass above the process unit could be dirty.
    • Silvertoast
      • Feb 2010
      • 270
      that or even fogged up scan mirrors ( have actually even seen the mirrors coated in nicotin causing light copies)
        • 23008
        What have you done so far? =^..^=
        • JustManuals
          • Jan 2006
          • 9838
          Paul@justmanuals.com
          • Dark Helmet
            • May 2009
            • 853
            In dirty enviroments ive seen the trail edge of the mirror on the polygon motor get dirty. Also the LSU glass can get toner dust and cause that as well.
            Clean:
            1st Mirrors
            2nd Laser Glass
            3rd Polygon motor. (security screw driver required to open LSU)
            Supplies on that machine are rated at 30k. When they got close to 30k CQ went down so check your supplies before you tear the laser out as it's a pain in the ass.
            • Akitu
              Legendary Frost Spec Tech
              • Oct 2010
              • 2595
              Check your charge grid and be sure it's clean... I had that yesterday albeit was on an ARM317. Charge grid was covered in toner and the top of the page faded out but the rest of it looked fine. Though it makes sense to check the laser glass first.
