DC 250 Fuser problem - 077-909
  • chombe
    • Jul 2025
    Hello Copytechnet-users
    I have problem with this error 077-909, it should be jammed paper in fuser but there is no paper. Actually what happend is that machine has pulled 2-3 papers at the same time and of course it stuck in the fuser. After i pulled the paper out it always says that paper is still jammed. I have tried with other fuser and everything is ok. So do you guys have any idea what can i do to save my new fuser
    Thanks.
  • tonerspot
    • Nov 2008
    • 79
    One of the IOT sensors detected paper when power was turned on or when an interlock was closed. check the fuser exit actuator
    • chombe
      Thanks for reply i will try that.
      • ExcellaGraphics
        I am having the same exact problem, except I dont have a 2nd fuser to help resolve the problem.
        what is "fuser exit actuator" and how exactly do I resolve this issue?
        • ExcellaGraphics
          Thanks.
          Did you find a solution? I dont have a 2nd fuser, I can't get a tech, and i'm looking to fix this...
          • jeanpaul
            • Mar 2009
            • 117
            • ExcellaGraphics
              Thanks for response...how do i adjust it into the correct position?
              • Agent
                same here
                hey
                i have the same problem here... .
                Tried to move it and touch it and everything, but nothin helped so far.
                Theres definietly no paper left in the machine, but still it says 077-909.
                • slybot
                  • Sep 2010
                  • 165
                  what sometimes happens is that the sensor flag/arm call it what you will, twists out of its holder and jams, hence the machine thinks that there is still paper. the flag/arm should pivot freely
                  • MlHAl
                    This thread solved my problem like a charm.... Thanks everybody!
                    • franzeee
                      Re: DC 250 Fuser problem - 077-909
                      Awesome! Thank you SO much! Saved the day Might want to mention that the fuser casing needs to be opened up to access the piece that is dislodged... Common sense to some, but others are very literal
                      Peace, harmony and healthy copiers to all
                      Franz
                      • slybot
                        • Sep 2010
                        • 165
                        Franz
                        hope it helped
                        • absolutcolor
                          Thank you for the diagram. I used a Q-tip to move the actuator arm back and forth to confirm it was free. The problem was solved.
                          • motts
                            I am getting the same fault code (077-909), however, it is on the Bypass Tray 5. Anyone know a fix for Tray 5? I check all the sensor locations and everything is clear.
                            • btibamanya
                              hi. have you solved the your problem? and how did you solved it pls tell coz I have the same problem but there is no any pc of paper.
                              the jam is on near registration roller.
