HP M479fdw torn mylar film on slit glass
  • allstar59
    • Oct 2012
    • 66
    I got a call on my first HP m479 for the adf jamming. The mylar film over the slit glass is torn. I got a service\parts manual but it only shows the ADF and scanner as a unit. Is that part available separately? If not what can be used in it's place?
    Thanks for any help,
    Jim
  • austonrush
    Sharp & HP Tech
    • 234
    Re: HP M479fdw torn mylar film on slit glass
    I don't believe HP ever made these, but you can find 3rd party aftermarket ones, that work just fine.
    Just search for HP M479 mylar strip
    • GIUBOSS
      • 1436
      Jim
      You could make it by cutting a sheet of transparent plastic to size, paying attention to the thickness
      • copyman
        Owner / Technician
        • Sep 2005
        • 4718
        I just had the same issue and ordered the aftermarket film. It came with adhesive strips on film and worked great! Over priced at $30 for 2 films but no other options unless you make them yourself.
