heavy noise on HP7815A
  • adeyemi
    • 379
    Can anyone help on this. The machine gives a very loud gear grinding noise shortly after switch on or during a print cycle. If the fuser is disconnected, noise is goes. All gears including those on the fuser are rotating properly outside load. I guess its the fuser, i don't even know where to source for one if this is confirmed as the faulty part. Plz help???
    Dgtal
  • jcbryan
    P3005 gears
    Most of the time the gear noise, comes from the small white gear on the inside frame, that drives the fuser. Or it is the fuser itself!
    • adeyemi
      • 379
      Thanks Jcbryan
      Dgtal
      • prntrfxr
        • 1622
        These are the part numbers of the offending parts:
        1.) RU5-0956 GEAR, 20/20T, FUSER DRIVE
        1.) RU5-0959 GEAR, 19-TOOTH, FUSER DRIVE
        1.) RU5-0958 GEAR, 17/17T, FUSER DRIVE ASSY.
        1.) RU5-0957 GEAR, 20-TOOTH, FUSER DRIVE
        1.) RC2-0657 FUSER THRUST STOPPER
        1) RC1-3609: BUSHING, LOWER PRESSURE ROLLER, RIGHT
        (1) RC1-3610: BUSHING, LOWER PRESSURE ROLLER, LEFT
        Life should NOT be a journey to the grave with the intention of arriving safely in an attractive and well-preserved body, but rather to skid in sideways - Coke in one hand - chocolate in the other - body thoroughly used up, totally worn out and screaming "WOO-HOO, what a ride!".
        • adeyemi
          • 379
          Thanks for this
          Dgtal
          • prntrfxr
            • 1622
            you're welcome. We sell a kit that has all these in it, but I figured you'd be looking for a vendor a bit closer to you.
            • adeyemi
              • 379
              Yes, you're quite far, but just for my info, how much? Maybe i could get back to u if i can't get it around
              Dgtal
              • prntrfxr
                • 1622
                I'll send you a PM.
