XM3250 ADF multifeeding
  • tech07
    • Aug 2008
    • 409
    [Misc] XM3250 ADF multifeeding
    Starting to see these doc feeders multifeed the last 3 or 4 pages all at once. Never the first pages, just the last 3 or 4. It's almost becoming a trend. What concerns me is that alot of them have less than 10k. Lexmark support has no advice except to change adf feed and sep rollers. I've tried a little more pressure on sep roller, but putting in new rollers has been the only option so far. Am I the only one seeing this ?
  • dalewb74
    • Feb 2018
    • 1151
    Re: XM3250 ADF multifeeding
    haven't seen it myself, but is the issue fixed if you replace the recommended rollers? or does it keep multi-feeding with new rollers as well? are you getting a jam code? if so what's the code?
    • flippinsweet
      • Oct 2013
      • 34
      I've had this problem on quite a few of these machines pretty much straight out the box, in some cases we've had to change to another model as the ADF was constantly multi feeding and jamming even with new rollers.
      Decent machines printing wise but when it comes to scanning I find them pretty useless. There is a bulletin about changing the top cover because sometimes it pops open and causes jams, not sure if this is related to multi feeding though.
      • driving lots of miles
        • Jun 2016
        • 398
        The ADF seems to be a weak spot in most of the Lexmark machines.
          • 23007
          Theoretically you would want to decrease the spring pressure on a separation roller. You'd want to increase the spring pressure on a separation pad. =^..^=
          • arnh79
            • 468
            I've had the same issue on this series. I did a warranty claim on the sep roller and the replacement part Lexmark shipped me was different. Unfortunately, I didn't keep the old roller assembly so I can't remember what was changed except that it was related to the sheet/pad that rests just before the roller. Since I replaced the sep roller assembly I haven't had an issue.
            Why does every customer think they're the first one to ever say: "you've been here so much we should get you an office, ha, ha, ha"?
            • Nachoman4life
              • Oct 2007
              • 212
              They added a spacer under the sep pad before the roller to push the pad up more.
              Where the heck is my spring hook?
              • TonerTrouble
                • Oct 2019
                • 2
                I too have this issue, did the warranty and the sep roller they sent to me had a small 2 stamped on the back, worked good for 3 devices, now warranty is up but many more to go. I will try adding a spacer and let you all know how it goes.
                • poultryman17
                  • Dec 2014
                  • 10
                  updated pn# is 41X1325
