Lexmark CX922de Colors All Jacked up....
  • Doug James
    • Jan 2012
    • 935
    [CQ] Lexmark CX922de Colors All Jacked up....
    Not even sure where to begin on this. Black and white works fine. Problem appears to be mainly cyan. (Pic Attached) The developers are all loaded correctly. I can make the copy lighter and darker but all look like this. Swapped the photoreceptors. Any idea's where to go from here would be very helpful Thanks so much !!!
    Re: Lexmark CX922de Colors All Jacked up....
    Try color registration and calibration
      • 22997
      I'd start with a new cyan developing unit/toner cartridge.
      The cyan parts of the image look composite black, like somebody dumped the waste toner bottle into the cyan toner cartridge.
      • Doug James
        • Jan 2012
        • 935
        Appreciate you guys. I will give that a shot, Calibrating and Developer and toner. Going back Thursday and I will let ya know... I have also seen people put waste toner in toner cart. Seems like that type of issue. Again THANKS !!!
        • techandtrader
          • Jun 2016
          • 318
          Wow On the small machines you can put the dev units in wrong and get this kind of result. Cx517. Dont get distracted!
          I have used Canon Imagerunner parts for sale. Most are floor model Color and / Advances Imagerunner with some 3025 3235 parts. Several intact machines being parted.
          • Doug James
            • Jan 2012
            • 935
            Turns out that when I took a closer look at the Cyan developer cartridge there was little developer in it. At $1200 ea customer decided to junk machine. Good since not sure what caused the problem.....
            • dalewb74
              • Feb 2018
              • 1125
              they junked the copier? those are fairly new models. if you are a lexmark dealer i would even say most likely the parts are still under warranty. though purchase date is a factor. but i guess it's still the customers call, especially if it's not under a maintenance contract.
              • Doug James
                • Jan 2012
                • 935
                Just out of warranty. They were Oklahoma Military Dept....
