Lexmark X464de-stuck at boot screen
  • savi0r
    • Sep 2010
    • 363
    [Dead] Lexmark X464de-stuck at boot screen
    Hello all. I have a Lexmark X464de that is getting stuck at boot screen. It loads about one quarter on the loading bar and gets stuck there. The customer usually switched off the machine by removing the power cord from the wall outlet, so i suspect a software problem. The pc doesn;t see the machine on usb or lan. i was thinking of forced firmware on the machine, but i don't know the procedure. Any help would be appreciated. Thank you
    • 23002
    Re: Lexmark X464de-stuck at boot screen
    I would suspect that the HDD crashed. Start by disconnecting the HDD. If it boots, you know that the HDD is toast. =^..^=
    • savi0r
      • Sep 2010
      • 363
      it doesn't have a hard drive. motherboard gone?
        • 23002
        The HDD is an option, so it probably never had one. Yes, control board ... if you can get it. =^..^=
        • savi0r
          • Sep 2010
          • 363
          Thank you!
          • dalewb74
            • Feb 2018
            • 1137
            due to the age of this machine your best bet is to purchase a new model.
