Hello, I encountered this problem, please help konica minolta bizhub C554e ( serial number needs to be entered contact your service representative ) When I lit it, it gives me this message, the serial number. I changed the memory battery. It was expired. Is there any help how to enter this number, knowing that the programs on the screen do not work and the serial number is written on the copier? I want the input method or the C554e Bizhub firmware link. Thank you
help me serial number needs to be entered contact your service representative
Re: help me serial number needs to be entered contact your service representative
Hello, I encountered this problem, please help konica minolta bizhub C554e ( serial number needs to be entered contact your service representative ) When I lit it, it gives me this message, the serial number. I changed the memory battery. It was expired. Is there any help how to enter this number, knowing that the programs on the screen do not work and the serial number is written on the copier? I want the input method or the C554e Bizhub firmware link. Thank you -
Thank you, brother. I entered the settings and found these boxes. Where do I enter the serial number? Do I enter it in all the boxes or only one? Thank youAttached FilesComment
You must enter the serial number only in the PRINTER field. However, if you are not a technician, there will be other steps to follow that need knowledge. I advise you to call a technician and have your machine back.Comment
once the battery died you opened a floodgate..I've seen this require the replacement of the majority of consumables..It's too late now, but there was a firmware released that changes where the NVRAM info is stored so that a dead battery does not result in this. You will have to replace the drum or check to see if the PPLM modifications may have been reset back to factory defaults as well. If you have any more of these e series I would do everything possible to get this firmware and add it to your devices. EComment
To get rid of drum warning just go to setvice mode. Hit stop 0 c. There you will find life warning just see all to off. Might be stop 9 c. Eithet way its there. I just did this.Comment
GHV-M1 released in 2019
2.2.1 Fixed issues
The following issues are solved in this firmware.
1. After turning OFF/ON the Main Power, the entry screen of serial number may be displayed in English and the MFP may not start. (ERBJTG1800912351 and others).Comment
Hello brothers, I have changed drum unit and the message is still there, knowing that I deleted it from the settings. Please, do you have a full flash bizhub C554e that passes the USB to bring it back to its original mind, send me the download link, and thank you very much for helping me solve the problemComment
I just had this issue on a remote island e series machine, the battery was flat and it also corrupted the SSD. I would advise replacing both if the battery is flat / leaking using the "at the same time" special procedure. Meter reading will be reset to 0 doing this and the machine will need to be setup again using the original out of box instructions to clear the lines of shame security feature.Comment
I feel like I want to run right away.
Contact your nearest Minolta technician.
Mishandling may result in irreversible damage.Comment
I'm having this same issue and my Konica Minolta c454e is sitting for days and don't know what to do to it.Comment
