1250P ghosting or shadowing
  • larweedad
    • 92
    We have a 1250P with 14 million prints. Drum, Developer, Belt, and Transfer Roller, Has been changed or replaced new. It is leaving a ghost or shadow like above the image not below. It is not the Fuser, because it is before and it shows up when we stop the print before the fuser.
  • wjurls
    • Feb 2017
    • 496
    Re: 1250P ghosting or shadowing
    How many miles are on the developing unit itself? If more than 5 million it needs to be replaced. Also check the cleaning input shaft and bearing (drives the cleaning brush in cleaning unit) The coupling will wear and the brush will lose it's ground.
    • Ziggy
      • Feb 2018
      • 713
      also check and and see if H toner was put in machine
        • 23006
        Halos like this are usually developing related:
        wrong toner
        overtoning
        • tulintron
          • Jul 2014
          • 668
          wrong toner
          overtoning
          +1.
