The random thought thread
  • allan
    RTFM!!
    • 5462
    #1846
    Re: The random thought thread
    hehe missed that. A chart with the roller circumferences would be grate. Cant recall seeing one.
    Whatever
      • 23010
      #1847
      The first time this came up for me was the Copystar CS-8030. The duplex roller wears only at the rear, making the roller slightly conical, and consequently skewing the second side, until it jams. This roller is rather difficult to examine. The trick that I came up with is to cut a couple 4mm wide strips of paper. To each I add a piece of tape. Then you can stick the tape to the roller, roll it onto the roller and make a pen mark where it laps. Then you can get a fairly accurate circumference measurement without removing the roller. When the difference in circumference exceeds 1.3mm, the paper just won't pass. And that's not very much, ~0.4138mm difference in diameter.
      Misfeeds (Jam J60, J61, J62, J63) entering the duplex tray for face down delivery. Paper Z-folded in the duplex tray with the rear leading corner flipped. Duplex switchback roller wears more at machine rear. Rough test: Lay your 6" scale along top of the roller. If it touches the guide at rear, replace. Precise test: Using a paper ruler measure roller's circumference at rear. New: 65.3mm. Worn: 64.0mm. Replace duplex switchback roller (302FB19401).
      • ZOOTECH
        Senior member of CRS
        • 3378
        #1848
        HP service manuals usually have the frequency of repeating 'marks' with diameters of feed rollers, fuser rollers, etc.
        • Iowatech
          Not a service manager
          • 3930
          #1849
          Will it mow?
          (Don't do this at home!)
          • Lagonda
            • Aug 2008
            • 1649
            #1850
            It's Monday morning and the new job booking system inflicted on me by our wonderful IT department has sunk without trace and f#@%&d my week completely.
            Can't I go back to giving people written instructions on a piece of paper?
            It works.
              • 23010
              #1851
              [ATTACH=CONFIG]34872[/ATTACH]
              It works.
              I've always liked paper:
              I can read it as many times as necessary.
              I don't have to log in to see it.
              I don't have to re-write it if the information isn't saved.
              It doesn't cost thousands of dollars to buy and/or maintain.
              It doesn't generate reams of statistics to be rubbed under my nose.
              When I first started in this business the call center faxed over a list of calls that came in the previous day. We would sort the calls out, primarily based on geography, then we would leave the office with 5 slips of paper in our pockets. The next morning we would fax the calls into the main office, get 5 more, wash rinse repeat.
              It worked just fine, for years. =^..^=
              • Iowatech
                • 3930
                #1852
                Meet the Laundroid!
                I heard that Panasonic doesn't make MFDs or printers any more, which if true is a shame as I liked the Panasonic equipment I got to work on back in the analog days.
                But hey, maybe they'll do better with this.
                As usual, open the link at your own peril. Also, the video at the link doesn't explain anything.
                • TheBlueOrleans
                  • Aug 2012
                  • 232
                  #1853
                  Random thought thread random thought. Technically a quote if you're a stickler.
                  God damn these electric sex pants.
                  Somewhere there is a tree working hard to produce oxygen for you to live, NOW GO APOLOGIZE TO IT!
                  • nottoosharp
                    • 266
                    #1854
                    omg! Shocking!
                    ... go home freelance hack
                    • Iowatech
                      • 3930
                      #1855
                      Got the first measurable snow yesterday (5", no big deal), so I changed my avatar accordingly.
                      If you're driving a car or pickup that is not terribly stable in the snow, a sixty pound tube of sand or two in the back might help. Five is kind of an excess though. I tried that when I was driving my little 2WD Ranger pickup years ago. It had the non-crew cab and the extended bed (fits a standard sheet of plywood), so storage space wasn't an issue.
                      (The last tube of sand I cut open was full of crushed limestone.)
                      • allan
                        RTFM!!
                        • 5462
                        #1856
                        Can you believe there is people like me who never touched snow before. Seen some from miles away.
                        Whatever
                        • allan
                          RTFM!!
                          • 5462
                          #1857
                          Hehe
                          ZOMBO
                          Whatever
                          • ZOOTECH
                            • 3378
                            #1858
                            "Reality is the leading cause of stress among those in touch with it."
                            Lily Tomlin
                            • NeoMatrix
                              Senior Tech.
                              • 3513
                              #1859
                              Re Snow droppings:
                              We had a problem with the neighbourhood trees and the birds leaving little white droppings everywhere, a huge mess. The trees have now been removed which has the added blessing of causing the noisy birds to move on.
                              I can remember looking towards the sky where the nieghbours trees once where with sincere thankfulness and true appreciation while I meantioned something to the affect of "thank christ cows don't fly"....
                              • nekowaiidesu
                                • Dec 2015
                                • 65
                                #1860
                                Hehe
                                ZOMBO
                                I've been waiting for this to load since 1999...
