unauthorized in konica forum
  • Synthohol
    Certified Konica Expert
    • 5841
    getting this message.
  • Synthohol
    • 5841
    now it let me post a reply but not the text copied from a webpage.
    it allowed me to paste it in the window but not post it.
    it showed in preview though just fine.
    anyway, weird.
    sorry.
    • Aneurysm
      Administrator
      • Jan 2005
      • 1083
      Hmmm... No Idea. I can't find anything in the permissions or channel setup. If you still have it can you PM me a link to whatever you were trying to post and I'll see if I can duplicate the error?
      • Synthohol
        • 5841
        • usb1.jpg Connect a USB cable to the USB port of this machine.
          • For details on the cable connection port, refer to
          • If a wizard screen appears to add new hardware, click [Cancel].
        • Insert the printer driver DVD into the DVD drive of the computer.
          • Make sure that the installer starts, and then go to Step 3.
          • If the installer does not start, open the printer driver folder on the DVD, double-click [Setup.exe] (in the 32-bit environment) or [Setup64.exe] (in the 64-bit environment), and then go to Step 4.
          • If the [User Account Control] window appears, click [Continue] or [Yes].
        • Click [Printer Install].
        • Read the license agreement, then click [AGREE].
        • Select your machine from [Product/Model], then click [Next].
        • Select [Install printers/MFPs], then click [Next].
          Printers being connected via USB ports are detected.
        • Synthohol
          • 5841
          lol, thats what i tried to post in the konica forum on copymans thread when i got the message.
          works here
            • 23008
            It seems to post here.
              • 37517
              This morning when clicking on a link in an email noticfication I am getting the following
              Sorry, you are not authorized to view this page. For assistance contact the site administrator.
              Here is a portion of the email to include the link.
              copier tech has made a new post under
              Recommended smtp sever for scan to email
              The discussion is located at:
              https://www.copytechnet.com/node/1578858
              Here is a preview (may be truncated):
              Edit: I later found that copier tech had apparently deleted his comment.
              Second edit:Apparently not being able to view the comment prevents refreshing the Ricoh forum from clearing the indication on the main Forums page that there are unread posts on the Ricoh forum. I had to use the Mark This Forum as Read at the bottom to clear it.
              • Duplicator
                • May 2022
                • 246
                I am also getting the "Sorry, you are not authorized to view this page. For assistance contact the site administrator." message when trying to view a thread in the Konica Minolta forum.
                The link to the thread I was trying to view at the time was: https://www.copytechnet.com/forum/te...nnection-error
                Maybe the entire thread was deleted or somehow marked as private? Not sure, not much error to go on there. Just figured I would report it in case it's a wider spread issue.
                Worked in IT for 12 years from Helpdesk up to System Administrator. Now working as the IT Manager at a copier company for the last 4 years.
                If I helped you out, please give me a thumbs up! It helps my reputation.
                  • 37517
                  More likely if you are clicking on a link in an email notification, the post that generated the email has been deleted. Next time try logging in to CTN then go to the KM forum and locate the thread. A reply with the same time that the email was sent will not exist. If you look at the link in the email it will end in a number not a thread name. That number is the sequence number of the post. If the post is then deleted, the sequence number is also deleted. Using sequence numbers allows faster finding of posts.
                  • tsbservice
                    Field tech
                    • 8020
                    The whole topic is missing probably deleted by poster although I'm not sure you can delete topic in a matter of short time or somehow.
                    Good eye.
                    • Duplicator
                      • May 2022
                      • 246
                      It showed up as the last updated thread on the main page at the time. I clicked the link and -BAM- error. I did notice shortly after however that entering the Konica Minolta forum the thread didn't appear. However, it did show up as the last updated item. I tried refreshing the page several times just to see if it was some weird caching thing but it hung around. The email thing is really strange. I would have thought vBulletin would just give you the first post in the thread if it can't find the sequence number. Maybe not. Oh, the missing sequence number in my pasted link thing? It was probably there in the browser but I think my copy and paste got truncated.
                      Good eye.
                      I'm also not sure what rules exist around a poster being able to delete their thread. I don't recall ever making a new thread, just replying to them.
                        • 37517
                        Good eye.
                        You can delete anything you post within a set length of time. One day or less. Also the system's spam guard can delete suspect posts.
                        • tsbservice
                          Field tech
                          • 8020
                          Now it is back, go figure. Somehow topic disappeared for a while...
                          • Synthohol
                            • 5841
                            got a post moderate message because i tried to edit spelling errors twice.
                            https://www.copytechnet.com/forum/te...5-bizhub-c7000
