now it let me post a reply but not the text copied from a webpage.
it allowed me to paste it in the window but not post it.
it showed in preview though just fine.
anyway, weird.
sorry.
Hmmm... No Idea. I can't find anything in the permissions or channel setup. If you still have it can you PM me a link to whatever you were trying to post and I'll see if I can duplicate the error?
usb1.jpg Connect a USB cable to the USB port of this machine.
For details on the cable connection port, refer to
If a wizard screen appears to add new hardware, click [Cancel].
Insert the printer driver DVD into the DVD drive of the computer.
Make sure that the installer starts, and then go to Step 3.
If the installer does not start, open the printer driver folder on the DVD, double-click [Setup.exe] (in the 32-bit environment) or [Setup64.exe] (in the 64-bit environment), and then go to Step 4.
If the [User Account Control] window appears, click [Continue] or [Yes].
Click [Printer Install].
Read the license agreement, then click [AGREE].
Select your machine from [Product/Model], then click [Next].
Select [Install printers/MFPs], then click [Next].
Printers being connected via USB ports are detected.
Edit: I later found that copier tech had apparently deleted his comment.
Second edit:Apparently not being able to view the comment prevents refreshing the Ricoh forum from clearing the indication on the main Forums page that there are unread posts on the Ricoh forum. I had to use the Mark This Forum as Read at the bottom to clear it.
I am also getting the "Sorry, you are not authorized to view this page. For assistance contact the site administrator." message when trying to view a thread in the Konica Minolta forum.
Maybe the entire thread was deleted or somehow marked as private? Not sure, not much error to go on there. Just figured I would report it in case it's a wider spread issue.
Worked in IT for 12 years from Helpdesk up to System Administrator. Now working as the IT Manager at a copier company for the last 4 years.
More likely if you are clicking on a link in an email notification, the post that generated the email has been deleted. Next time try logging in to CTN then go to the KM forum and locate the thread. A reply with the same time that the email was sent will not exist. If you look at the link in the email it will end in a number not a thread name. That number is the sequence number of the post. If the post is then deleted, the sequence number is also deleted. Using sequence numbers allows faster finding of posts.
The whole topic is missing probably deleted by poster although I'm not sure you can delete topic in a matter of short time or somehow.
Good eye.
It showed up as the last updated thread on the main page at the time. I clicked the link and -BAM- error. I did notice shortly after however that entering the Konica Minolta forum the thread didn't appear. However, it did show up as the last updated item. I tried refreshing the page several times just to see if it was some weird caching thing but it hung around. The email thing is really strange. I would have thought vBulletin would just give you the first post in the thread if it can't find the sequence number. Maybe not. Oh, the missing sequence number in my pasted link thing? It was probably there in the browser but I think my copy and paste got truncated.
Good eye.
I'm also not sure what rules exist around a poster being able to delete their thread. I don't recall ever making a new thread, just replying to them.
Now it is back, go figure. Somehow topic disappeared for a while...
