Canon CLC3200 out of focus copies.
  • tinnyjay
    • Oct 2009
    • 663
    Hello!
    We have a Canon CLC3200 with changed parts(fuser,drums,) but when copy it prints a foggy image like images below.TB is changed 3-4 times but with used TBs and sensors are cleaned,installed new firmware,full adjusted(user adjustment mode) and still the same thing.Please help me if you can
    "Who loves the roses,must also bear thumbs"
  • SCREWTAPE
    East Coast Imaging
    • 3396
    Your registration is off.
    Are you a tech?
    Check out this thread you should find some info on your issue.
    http://www.copytechnet.com/forums/ca...on-models.html
    • tinnyjay
      • Oct 2009
      • 663
      Are you a tech?
      Please can you tell me which registration is off?(inside TB unit) I am a tech,but i am not trained on these machines).
      • blazebusiness
        SanDiegoCopierRepair.com
        • 1257
        A lot of things might be causing this problem. But I guess I would start with the ITB belt - might be slipping, you could try cleaning the belt interior and drive rollers. Replacing it with a used belt is not the way to go.
        After cleaning those drive rollers (and replacing the cleaning blade while you are in there) test it again. If still blurry you may have a problem with itb drive assy. Problems like this are also sometimes resolved by adjusting the lasers but in your case I'll bet not. Focus your efforts on the ITB unit drive or slipping problems.
        • Fer
          • Nov 2009
          • 267
          This a very common problem on the 3200 model.
          Root cause is the slipping of the ITB (transfer belt).
          U should start with cleaning inside or replace the belt, also clean de drive roller. That is the thick black rubber roller. Use a good rubber cleaner en clean it thourough.
          Sometimes the slipping causes the calibration routine to get stuck. U can reset it with a dc-con clear. Just remember to make p-print first, a put the p-print values back in the cleared dc controller.
          If that doesn;t work, u can get out the lasers and put them in home possition manually.
          All these tricks can be found in detail in former topics on this board.
          Good luck.
          • blazebusiness
            • 1257
            Good luck.
            I agree with Fer that a dcon clr might also help. If you use rubber cleaner on that black roller-don't use it on anything else. Do not clean the belt interior with rubber cleaner! Use alcohol or water dampened cloth.
            • tinnyjay
              • Oct 2009
              • 663
              Something else i learned about this copier.One of my guys said me he reset the copier(Factory Settings) and now i am thinking if any value in Service Mode must set to another values.
              After i made a Full Adjust the copier printed test page and the colors was perfectly correct,but not in a straight line.Yellow was 3 mm up,black was 2-3 mm down and so two other colors but the block of colors was wanderful.Maybe this helps.
              • Fer
                • Nov 2009
                • 267
                If he did a dc-con clear, he should also put the values of copier, adjust back. Maybe there is a paper in the door compartment with the factory values.
                • tinnyjay
                  • Oct 2009
                  • 663
                  Yeah,i found the paper with values.Are they right tu put'em back?
                  • blazebusiness
                    • 1257
                    No harm in doing that. Certainly worth a try and those values should always be entered anyway after performing a clear.
                    My money is still on a problem with the ITB though.
                    • teckat
                      • 16083
                      yeah,i found the paper with values.are they right tu put'em back?
                      Preventive measures for possible color displacement in the paper feed (sub scanning) and the main scan (front
                      to rear) direction
                      read this pdf for 3200-3220
                      iR3200-3220 TP03.pdf
                      I'm such a nice guy
                      • SCREWTAPE
                        East Coast Imaging
                        • 3396
                        Firmware is important too.
                        Especially DCCON.
                        When I used to work on these, I had that Tech pub in my bag.
                        • tinnyjay
                          • Oct 2009
                          • 663
                          to rear) direction
                          [ATTACH]6664[/ATTACH]
                          I'm such a nice guy
                          Not just a nice guy,but a very nice guy
                          • Fer
                            • Nov 2009
                            • 267
                            From his first post i assume that with TB, he meant ITB Assy.
                            • tinnyjay
                              • Oct 2009
                              • 663
                              Yes,its true
