C654e
+ More Options
Posts
  • tufbnme
    • 493
    C654e
    I'm a Ricoh guy and what I thought was a good customer purchased a used C654e (instead of the Ricoh I proposed), anyway, he would like me to set it up, install the bridge unit and finisher. I connected them but the machine does not recognize them, I guess something may need to be turned on in the service mode.
    First, how do I enter the service mode?
    second, once in where do I need to go
    and third if anyone has a manual for sale let me know.
  • Synthohol
    Certified Konica Expert
    • 5888
    Re: C654e
    nothing needs to be setup. you have 2 cables to hook up 1 from bridge to finisher and from finisher to the upper left corner where the ADF wire is.
    as far as a manual, i play drums so your avatar gets you a link in a PM in a minute
    • tufbnme
      • 493
      Re: C654e
      Thanks for the info. I hooked up the bridge and finisher, connected the wires but still no recognition.
        • 23010
        Re: C654e
        Which wires?
        Was the machine fully Off (not just the switch on the op panel)?
        Did you follow the setup instructions?
        Have you updated firmware?
        What models of accessories?
        • tufbnme
          • 493
          Re: C654e
          The wires coming from the bridge and the finisher (FS535) I have no installation instructions, can't find it in the manual either. Turned it off on the main switch (not just op panel)
          • Woxner
            • Jul 2011
            • 852
            Re: C654e
            here is the install info
              • 23010
              Re: C654e
              You'll need to plug in the cable from the finisher to the back of the machine also. =^..^=
                • 23010
                Re: C654e
                Which wires?
                • Reed
                  • Feb 2011
                  • 258
                  Re: C654e
                  you may need to enter the serial number of the finisher into the machine for it to recognize that it is connected.
                  • allan
                    RTFM!!
                    • 5462
                    Re: C654e
                    Huh..
                    Whatever
                    • Reed
                      • Feb 2011
                      • 258
                      Re: C654e
                      Originally posted by allan
                      Huh..
                      I dont set up many new machines but I did recently set up a new c284e. In the set up instructions it was explained to go into the service menu under "System 1" you will find "Serial Number " press that and enter the associated serial number of the finisher.
                      When I was setting up the bizhub c284e I missed a step and it didn't work right until I went back through and entered everything properly. Not saying that it will recognize the finisher bit it's worth a shot
                      Sent from my SM-G920T using Tapatalk
                      • Albonline
                        • Sep 2008
                        • 1153
                        Re: C654e
                        Huh..
                        some earlier models required sn for perifs but nothing in the last 3 or 4 generations
                        • wjurls
                          • Feb 2017
                          • 501
                          Re: C654e
                          The bridge unit has a small PCB where the wiring plugs in. This PCB has a ICP on it. If this ICP is blown, the machine won't recognize the bridge or finisher.
                          Lee
                          The Copy Guys
                          Riverside, CA
