C360i firmware update problem
  • Synthohol
    Certified Konica Expert
    • 5861
    #16
    Re: C360i firmware update problem
    just a reminder of what drives are konica certified...
    • Ziggy
      • Feb 2018
      • 789
      #17
      Reminder sometimes usb sticks stop working and formatting with windows doesn't work you need to use HP formatter tool. See attached bulletin . You can find this tool on Konica Minolta's site
      • Don N.
        • Nov 2011
        • 409
        #18
        Originally posted by SUPERMIGHTYZ
        Problem solved. Key usb! Thanks
        Exactly what do you mean by KEY USB???
        Seemed like you said earlier you tried multiple USB drives???
        BTW, I have a C360i that won't load FW0020 from multiple USB's that work fine loading FW on other C250i/C300i/C360i machines. I'm holding the FW button, the dot appears, but never shows FW screen or loads FW. Eventually it reboots & stalls at about 50% progress bar.
        Machine was working fine, ran gradation & user test prints, etc. then it crapped out when I tried to upgrade FW. It's a lease return machine. Now a brick.
        I can't get into service mode either.
        • kingarthur
          • 1376
          #19
          You don't need to bother with the FWSelect folder.
          I keep multiple models with just the FW00020 folders etc on one 8GB USB pen drive.
          Same here, I've got FW for every colour model just "sitting" on my USB, no FWSelect folder
          • femaster
            • May 2011
            • 1514
            #20
            REDACTED DUE TO SENILITY...
            Last edited by femaster; 10-11-2023, 01:48 AM. Reason: Edited to correct a "moment of senility"
            • tsbservice
              Field tech
              • 8029
              #21
              FWSelect folder is if there are multiple firmwares for same model. Never used it one USB for all of them.
              • femaster
                • May 2011
                • 1514
                #22
                You are correct. I've redacted my previous post as the brain wasn't fully engaged at the time of posting.
                • tsbservice
                  Field tech
                  • 8029
                  #23
                  Ahhh, I see now my answer may appear like posting over yours...which wasn't meant at all. I apologize.
                  • femaster
                    • May 2011
                    • 1514
                    #24
                    No problem at all, and certainly wasn't taken that way. I removed it since the information I supplied was not completely correct, and the last thing I want floating around is wrong information that might lead someone else astray in the future.
                    • Rewind!
                      Somehow it works....
                      • Jan 2019
                      • 89
                      #25
                      I've also had end users unplug the USB passthrough cable to the board.... (8, I series). Beleive me when I say that i felt very dumb after 5 flashdrive swaps smh....
                      JC
                      • Bman
                        • Dec 2023
                        • 9
                        #26
                        I can't update firmware on the bizhub c360i series. I copy the firmware folder (FW000XX) to the root of the usb stick, but it does not start. The dot appears but then nothing ..Thanks to everyone who will help me Thanks to everyone who will help meI can't update firmware on the bizhub c360i series. I copy the firmware folder (FW000XX) to the root of the usb stick, but it does not start. The dot appears but then nothing ..Thanks to everyone who will help me
                        where you able to resolve this issue?
