C454e "TPM chip has been changed"
  • filladefilla
    • Apr 2024
    • 44
    #46
    serial numbers are in the correct place but HDD is set to uninstalled because HDD is set to installed, HDD errors pop up... so I set it to uninstalled.
    • Synthohol
      Certified Konica Expert
      • 5745
      #47
      ok, at least its not asking for movie data!
      in service hit stop 0 clear i think there is a place to backup/restore memory data
      also while in service make sure the ADF is set to the correct type (624 or 701) in system 2 i think?
      • filladefilla
        • Apr 2024
        • 44
        #48
        machine language has changed to Japanese ... So I'm unable to identify back/restore memory data or set ADF to (624 or 701).
        • Synthohol
          • 5745
          #49
          its supposed to reboot 3 times after using the reset tool, usually twice in JP then EN with the restore now.
          can you exit from that screen without hitting restore now? just curious.
          • Synthohol
            • 5745
            #50
            utility, #2 user settings, #1 system settings, #1 should be language settings if you can get there.
            also in system 1 in service mode make sure your marketing area is set correctly.
            • filladefilla
              • Apr 2024
              • 44
              #51
              I can't access user settings or system settings. Checked the marketing area and it's set to European.
              • filladefilla
                • Apr 2024
                • 44
                #52
                I'm getting fed up.
                • filladefilla
                  • Apr 2024
                  • 44
                  #53
                  Another error after logically formatting HDD
                  • Synthohol
                    • 5745
                    #54
                    down at the bottom something is set for JP japan.
                    maybe try changing it to EU?
                    • filladefilla
                      • Apr 2024
                      • 44
                      #55
                      Changed to US, yet language still appears in Japan.
                      • tsbservice
                        Field tech
                        • 7927
                        #56
                        You should boot with firmware stick and go to language selection and choose desired.
                        • filladefilla
                          • Apr 2024
                          • 44
                          #57
                          Exactly same thing has been done... after the firmware update, language changes to Japanese.
                          • filladefilla
                            • Apr 2024
                            • 44
                            #58
                            Please, what's the solution to this problem.
                            Thank you.
                            • filladefilla
                              • Apr 2024
                              • 44
                              #59
                              this process can continue for 24 hours non-stop. when I restart it on my own, TPM error appears.
                              Please help
                              • Synthohol
                                • 5745
                                #60
                                is the original mfp and ssd installed?
