C454e "TPM chip has been changed"
  • tsbservice
    Field tech
    • 7927
    #31
    You're stuck...maybe a time to call real technician.
    • copyman
      Owner / Technician
      • Sep 2005
      • 4546
      #32
      I would use reset FW and follow procedure exactly.
      • Synthohol
        Certified Konica Expert
        • 5741
        #33
        he did!
        it rebooted with the 390, recover data came up so he hit it and thats where it sticks.
        i think the backup data on the other boards it pulls the data from must be corrupted or boards were mixed up mfp+ssd from another machine? i dont recall.
        he will have to give more details.
        • copyman
          Owner / Technician
          • Sep 2005
          • 4546
          #34
          I meant try reset FW again and follow procedure. There were a few times I had to use reset FW again and it worked.
          • filladefilla
            • Apr 2024
            • 43
            #35
            Originally posted by Synthohol
            he did!
            I have reset the fw again and again, and again. after successfully resetting...I will insert the firmware stick. and I will be stuck at recovery data.
            • filladefilla
              • Apr 2024
              • 43
              #36
              currently, I have applied G20 m1 f/w update.
              Language has changed to Japanese language
              the error "TPM chip has been initialize is back.
              and Error code "CD010* is showing as well.
              • filladefilla
                • Apr 2024
                • 43
                #37
                Called a Technician, he came to changed MFB etc. but he couldn't help and left.
                In my country not many Technician are Konica technicians...most of them are Canon Technicians.
                • Synthohol
                  • 5741
                  #38
                  was anything else replaced other than the battery?
                  • filladefilla
                    • Apr 2024
                    • 43
                    #39
                    I swapped the SSD and HDD from similar machine and the issue was there so I replaced the the parts back.
                    • filladefilla
                      • Apr 2024
                      • 43
                      #40
                      After changing the battery, I followed the instructions below and I got stuck at number 9.
                      Solution
                      CAUSE: Issue will occur after turning off the machine for a while specially after the weekend.
                      SOLUTION:
                      1. Have a new, unused SSDB, but do not install it yet.
                      2. Order a new MFP Board
                      3. Flash the MFPB with the Reset Tool 3 Times total with the old SSD Board.
                      4. Once the 3rd flash of the MFPB says complete, turn off the MFP (DO NOT REBOOT).
                      5. Install the new SSDB.
                      6. Insert firmware stick with (latest base firmware) and turn the MFP on.
                      7. When the firmware screen comes up check/correct Machine and Type, then flash firmware.
                      8. After firmware has loaded, turn on the MFP normally.
                      9. You may or may not get a CD390, Allow the MFP to perform it's recovery process if the CD390
                      occurs.
                      10.When the machine comes up, it should behave like a brand new machine again and will need serial
                      number entered.
                      11. In some cases, the entire install process may need to be done (security lines might occur.)
                      12.Install the preventive firmware GHVM1​
                      • Synthohol
                        • 5741
                        #41
                        i think you have to format the ssd.
                        when the mismatched ssd was installed i think it brainfarted something so when the original ssd was reinstalled it had a fit.
                        unless i misunderstood your procedures?
                        • Synthohol
                          • 5741
                          #42
                          5.4.10 SSD board (SSDB)
                          NOTE
                          • Never use the combination of the used SSD board removed from another machine and the original MFP board. This combination
                          causes corruption of stored data.
                          Note that the combination of the original SSD board and the used MFP board removed from another machine also causes the same problem.
                          • Do not replace the printer control board and the SSD board with new ones at the same time. The backup data is lost and image
                          failure may be caused.
                          • Do not replace the MFP board and the SSD board with new ones at the same time
                          if you hold down panel reset and boot up can you get to trouble reset mode?
                          while holding down the button it should beep with a black dot on the screen. you can let go and wait and see if trouble reset comes up.
                          you should be able to access service mode with the normal stop,0,0stop,0,1 from that screen.
                          also it usually wont hurt to hit trouble reset before entering service mode.
                          • filladefilla
                            • Apr 2024
                            • 43
                            #43
                            NOTE
                            Yes, please, I am able to access service mode from there. I have done trouble reset yet I still get D390 error after reboot.
                            • Synthohol
                              • 5741
                              #44
                              ok, in service mode are the correct serial numbers in the right place?
                              is the hdd set to installed? if it just beeps thats ok, ive seen it take 4 or 5 minutes to change on the screen
                              • filladefilla
                                • Apr 2024
                                • 43
                                #45
                                serial numbers are in the correct place but HDD is set to uninstalled because HDD is installed, HDD errors pop up... so I set it to uninstalled.
