C554 vs c454 fuser?
  • mrfuser
    • 1627
    C554 vs c454 fuser?
    Anyone know what the difference is between the c554 and c454 fusers?
  • emujo2
    • Mar 2017
    • 1579
    Re: C554 vs c454 fuser?
    A2XKR71044--c554
    A4FJR70244--c454
    Probably wired different and drive gear differences.
    • adecanmin
      • Oct 2010
      • 322
      Two things. The electrical connection are different. The c554 has much bigger bearings supporting the fuser sleeve roller. The c454 has the small bearings that disintegrate.
      • mrfuser
        • 1627
        Thanks. The C554 has cleaning roller bushings that are toast along with the cleaning roller. Now to find part numbers for ordering . Lots of fun
        • copyman
          Owner / Technician
          • Sep 2005
          • 4788
          Probably the most common issue with the models that use that style fuser.
          Brush Cleaning Roller A2XK740400
          Teflon Cleaning Roller A2XK740301
          Cleaning roller bushing A2XK742901
          Brush roller bushing A161771000
          There may be new style / color bushings?
          Ball bearing 4120550302
          The small bearings that disintegrates is used in a lot of finishers, FS 527, FS 534, etc. I take them out to use in these fusers when I strip parts off finishers before trashing.
          • mrfuser
            • 1627
            thank you so much for saving me a lot of time!
            • mascan42
              • Oct 2008
              • 487
              Also available as a repair kit HHFRC754E-C754A, used for 554, 654 and 754 models. Recommend using hi-temp grease on bushings.
              • copyman
                Owner / Technician
                • Sep 2005
                • 4788
                Also wanted to add I've seen both cleaning rollers removed and machine ran 100's of thousands prints with no fuser issues. All single side of course, don't think it would hold up well with a lot of 2 sided.
                I've personally left the cleaning rollers out out for a few weeks while getting parts and returning. No unusal build up on rollers, etc. Rollers look fine. Think you could leave them out permanently on high volume account that run mostly 20lb plain paper single side only, but don't hold me to it
                • copier tech
                  • 8236
                  I usually remove that cleaning roller ass'y when they start to wear out machine runs fine without it.
                  • srvctec
                    Former KM Senior Tech
                    • Oct 2009
                    • 827
                    The whole assy. with both cleaning rollers or just one of the roller assys? If just one of the rollers, which one? We've never tried removing either of them so I was wanting the inside info.
                    Started in the copier service business in the fall of 1988 and worked at the same company for 33.5 years, becoming the senior tech in 2004 but left to pursue another career on 4/29/22.
                    • copier tech
                      • 8236
                      • AL parts
                        • Jun 2019
                        • 61
                        The pressure rollers of the two models are different, the fixing film is different, and the sponge roller inside the fixing film is also different
                        www.gzanling.com
                        • femaster
                          • May 2011
                          • 1527
                          What we do is just remove the brush roller assembly once that bushing wears out on it. It's as simple as removing the 2 small springs and 1 E-clip. The brush roller assembly then slides to the side a little bit and comes right out. Have never had a problem with dirty pages because of removing the brush roller.
                          • mrfuser
                            • 1627
