C-364e, not accepting firmware above J6...
  • Oystercopy
    • Oct 2009
    • 623
    There's been a long time problem with updating F/W on this series machine... the machine will try to load "K" (for example) and stop and give an N.G. on the main controller F/W.
    I'm pretty sure someone has come across this and fixed it. Never had a problem uploading F/W to another other KM product, but I'm worried about this only because without later F/W, these machines start
    acting squirrely.
    Thanks in advance!
    OC
  • emujo2
    • Mar 2017
    • 1580
    Re: C-364e, not accepting firmware above J6...
    What is the reason you are updating firmware??Is there a problem with the machine that you think f/w addresses? Are you trying to go from a very old level to latest (and by latest I mean at least 6 years old). E
    • Synthohol
      Certified Konica Expert
      • Mar 2016
      • 5805
      back up the machine to USB, run a clear all data. try firmware again then movie data.
      if still NG, boot to firmware stick and select machine type, make sure they are not FF for both.
      ive seen that happen when the ssd reset tool is used incorrectly, resets machine type to FF and wont update the MFPB.
      good luck, i think my 1st suggestion (albeit time consuming) usually works as long as nobody did a naughty.
        • 22999
        I've seen this on a few Toshibas, a few Konica Minoltas. NG on a few of the firmware pieces, but! ... if you select only one firmware piece at a time it will load it successfully. Then the next, then the next. Sure it's inconvenient, but I've had it work several times.
        My theory is that the firmware files tend to grow in size with the various updates, which can tax the memory capabilities of the controller. By selecting only one piece at a time, it gets around that. Does that sound plausable?
        • Oystercopy
          • Oct 2009
          • 623
          Another tech private messaged me and provided me the solution, which was right under my nose the entire time. NO ONE at tech support, or Hytec or anyone knew how to get this working, but this guy did.
          The secret to the fix was to uninstall the HDD, then go in and thoroughly format the SSD ALONE, by itself, then reinstall HDD and load the next level of F/W...
          Unbelievable!
          Thanks to all!
          OC
            • 8132
            Unbelievable!
            Thanks to all!
            OC
            Thanks for sharing!
            When I have had this issue in the past it happens when the SSD is on an early version like 6.01 so to get round this I update to version 6.03 then the machine accepts the main firmware (it also updates the SSD to v 6.05)
            • tsbservice
              Field tech
              • 7981
              OC, Hail for an old smarka days!
              • Bix
                • Apr 2018
                • 1421
                It has often happened to me, the solution is to remove the options (finisher, ADF and Fax). Problem solved!
                • Oystercopy
                  • Oct 2009
                  • 623
                  Interesting... I've tried removing my accessories to make that work too but it never seemed to work for me.
                  And yes Smarka goes back a long way, TSB!
                  • tsbservice
                    Field tech
                    • 7981
                    It's not on a topic but is interesting how long such a connections work. Maybe 15-20 years ago I started with smarka and learned a lot, next I was giving help to others.
                    And yes you helped me an maybe I helped you on few Toshibas.
                    I tip my hat to guys like you with like 30-40 years and more in this industry, I have learned a lot and now it's my time to pay-off.
                    So have a GREAT day OC.
                    • SAR
                      • Jul 2009
                      • 203
                      That was a pretty common problem with the e series machines and they did have a bulletin on it.
                      Here is a copied and pasted version of it:
                      Note: Export all important data before doing this procedure.
                      Problem
                      "MFP=NG" message may be indicated when attempting to install firmware.
                      Solution
                      CAUSE: Possible corruption of the SSD board (SSDB) or Hard Disk Drive (HDD) unit.
                      SOLUTION: Before performing the steps below attempt to load firmware with the HDD physically disconnected from the MFPB. If the "MFP=NG" message returns then connect the HDD and proceed.
                      Format the HDD/SSD Procedure:
                      If able to access the Service Mode to format the HDD or SSD, perform the following steps.
                      WARNING
                      : Carefully follow the steps below, as doing so will avoid any unnecessary replacement components, such as the MFPB/PRCB/HDD (when only the SSD is actually required).
                      1. Press Menu.
                      2. Select Counter.
                      3. Select Display Keypad.
                      4. Access Service Mode "Stop 00" "Stop 01".
                      5. Enter 9272 4 times (Factory default).
                      6. Select System 2.
                      7. Select HDD and set to "Uninstall".
                      8. Select State Confirmation.
                      9. Select Memory/HDD Adj.
                      10. Press down-arrow 2/2.
                      11. Select SSD Format.
                      12. Select Logical Format.
                      13. Power MFP OFF/ON.
                      14. Repeat steps 1 through 5 to access Service Mode.
                      15. Select System 1.
                      16. Select Initialization.
                      17. Clear All Data.
                      18. Select System 2.
                      19. Select HDD and set to "Install".
                      20. Power MFP OFF/ON. \
                      21. Repeat steps 1 through 5 to access Service Mode.
                      22. Select State Confirmation.
                      23. Select Memory/HDD Adj.
                      24. Use the down-arrow to access page 2.
                      25. Select HDD Format.
                      26. Select Logical Format.
                      27. Power MFP OFF/ON.
                      • adecanmin
                        • Oct 2010
                        • 297
                        Problem
                        Solution
                        WARNING
                        1. Press Menu.
                        2. Select Counter.
                        6. Select System 2.
                        17. Clear All Data.
                        Should this procedure be done proactively? or only when there is a problem. Also does this apply to all e machines or just the c364e?
                        I've had this happen on a c364e but never on c454e.
                        • SAR
                          • Jul 2009
                          • 203
                          This procedure fixes a lot of weird issues that the C224e up to the C554e series had that were usually related to the SSD and HDD and memory.
                          We do this on all of these machines, if we have them in the shop. If it is a machine in the field, I leave it alone unless it is having issues. However, it can't hurt a thing if you want to do it proactively. Just be sure to export any data you don't want to lose when you format the machine.
                            • 8132
                            If you want to be proactive update the SSD firmware to V6.03 & you won't need to perform this procedure.
                            • emujo2
                              • Mar 2017
                              • 1580
                              V 6.05 is available now..Included with f/w version G9 this version pops up the SSD version # when you power up with the USB inserted..It will show SSD version 6.0x..If it's 02 it won't update, if it .03 it will auto update to 05. This stuff is almost 7 years old so I'm sure it's really not aplicable in the US market anymore. E
