BH C368 grabled/noisy print
  • Zesti
    • Jun 2009
    • 308
    [CQ] BH C368 grabled/noisy print
    Hi there,
    This C368 is prionting attaimage.jpgched sample print. To my experience the MFP board has gone bad. Any thoughts about it and what's reason for the fault.
  • tsbservice
    Field tech
    • 7972
    I would try another PH unit.
    • kingarthur
      • 1325
      carry out initialization and image stabilization - then gradation. that's once you've sorted the black lines
      • Max
        • Oct 2011
        • 552
        Have you replaced any drums before the problem?
        • Zesti
          • Jun 2009
          • 308
          I doubt about it. Cos same problems occur in older c550, C452 etc and the culprit was the MFP board.
          • Zesti
            • Jun 2009
            • 308
            Yes off course
            • Zesti
              • Jun 2009
              • 308
              Done already
              • copytechtrouble
                • Nov 2020
                • 95
                re-chip the drums. failing that, i would try a HVPS.
                • Ziggy
                  • Feb 2018
                  • 692
                  I second the PH unit. I've had this same problem before.
                  • Zesti
                    • Jun 2009
                    • 308
                    Will try that...thanks
                    • jotunn
                      • 606
                      First I would try cleaning polygon mirror in PH unit and SOS sensor - common problem with this machines in dusty environment - PH unit is not sealed very well, in extreme cases we had such problems once in a month, so we had to add additional sealing (sponges + tape around PH unit covers).
                      Next make [Print Head Skew Adj.] - > [Reset] then [Stabilization + Initialization].
                      If cleaning doesn't help replace PH unit.
                      Color registration highlited in the photo is not your main problem - main problem are lines across your prints, color registration problems are just the result.
                      • rrrohan
                        • Sep 2011
                        • 1977
                        if you remove print head/laser and tape over half of the glasses then reinstall and print and now half the page is gone it will confirm thats the problem. i recently had a fellow tech go down rabbit hole only to unplug laser and problems vanished. would hate u to do the same
                        • tsbservice
                          Field tech
                          • 7972
                          ?????So any news in this problem?
