Strip on
  • Carlos Rego
    • Mar 2024
    • 40
    Strip on
    I have a Konica Minolta Bizhub 458 and it stated to make a strip only on the black.
    Already changed Black drum and nothing, took a look on the revelation unit and seemed to be good
    This gallery has 1 photos.
  • copier tech
    • 8215
    Clean the laser glass with the tool inside the front cover.
    If this doesn't help the issue is with the developer unit.
    www.printerfirmware.co.uk
    • Ziggy
      • Feb 2018
      • 807
      pull the laser unit and clean glass. If its real dirty the wand in the door wont get it clean.
      • copyman
        Owner / Technician
        • Sep 2005
        • 4782
        +1 on the laser needing to be cleaned
        • Max
          • Oct 2011
          • 569
          A clump of toner behind the dev blade that's preventing the formation of a dev brush or crap on laser glass
          • Carlos Rego
            • Mar 2024
            • 40
            Tried cleaning laser glass ,but no luck.
            CHanged develop unit and nothing, still remains the same.
            • Synthohol
              Certified Konica Expert
              • 5902
              if not drum, not dv unit its the laser glass. you need a good strong flashlight and look for anything on the laser slit glass. the wand does nothing for staining, just loose toner dust.
              • Ziggy
                • Feb 2018
                • 807
                Did you pull out PH (laser) unit and clean? If you did and drum and developer unit has been replaced, pull PH back out and inspect area where the laser shines through to get to Drum. Something is blocking the laser from hitting Drum
                • Carlos Rego
                  • Mar 2024
                  • 40
                  Still haven't taken the ph out, going to try it next
