automatic touch panel calibration
  • Tiagocang
    • Feb 2022
    • 62
    hello, any1 know if its possible and how to do it, the automatic calibration of touch panel in C250i and C257i ?
    • 8188
    Press the home button, then accessibility you will see the touch calibration option there.
    www.printerfirmware.co.uk
    • Tiagocang
      • Feb 2022
      • 62
      i tried that before but when i try the calibration the left bottom i cannot make it work and i saw a video with automatic calibration with usb like FW update
      • kingarthur
        • 1375
        I'm not sure if this applies to the iSeries, i've got a note on my phone on how to carry out screen calibration - go to "Counter", "Display Keyboard" "Stop" "Clear" "1166" "Start" - then it says "Reboot after 30 seconds", whether the device reboots, or you have to, I can't remember
        • tsbservice
          Field tech
          • 8029
          Tiagocang , check your PM
          • Woxner
            • Jul 2011
            • 852
            • Ziggy
              • Feb 2018
              • 789
              Put usb stick in that has firmware on it and hold the bottom button on back of control panel instead of the top button. That should automatically launch the touch panel calibration
