KM 364e: washed out stripe
  • zodiaco
    • Feb 2021
    • 27
    Hi, my Bizhub 364e is printing a white stripe on all pages, always in the same location. Total page count is 180k. With the incredible help of an experienced CNT forum member, I tried these fixes:
    - replaced drum
    - replaced toner with KM original
    - replaced transfer belt assy with original
    - pulled laser printhead and cleaned glass slit with isopropyl and dry lint
    - inspected and cleaned fuser rollers
    I am at my wits end - what is next?
    Thank you!
  • copytechtrouble
    • Nov 2020
    • 98
    It seems like you've covered everything. As its an uneven stripe it does look to me like a dirty laser blocking the light but you've already covered that.
    can you go into Service mode-Test Mode-Halftone Pattern and print off A3 prints for each colour at full (255) and half (128) Bleed and see what they look like?
    • copyman
      Owner / Technician
      • Sep 2005
      • 4633
      It's a B&W model not color. I feel bad as I've assisted this member offline for a long time and he has tried everything I suggested and still same issue. As last resort I suggested he pull laser & clean and after he reinstalled problem went away, but came back after a day or so. Since cleaning Laser Print head worked for a short while this leads me to believe the PH or front side board is bad, only things he hasn't replaced.....
      • copytechtrouble
        • Nov 2020
        • 98
        It is indeed a B&W machine, forgive me I misread the initial post. yeah I think a new (or known good 2nd hand) laser unit would be the next thing to try.
        • femaster
          • May 2011
          • 1482
          Transfer roller dirty or worn down in the faded area? Feed direction is not specified, so just a guess.
          • tsbservice
            Field tech
            • 7981
            I would inspect DV unit for dirth inside left from garbage toner. You can even dump it vacuum it thoroughly and sieve the mixture(not for the beginner).
            • Ziggy
              • Feb 2018
              • 693
              If it worked after cleaning the laser try there is a chance that if you were using non OEM toner the developer unit is contaminated and dumping toner on the laser. Pull laser again to see if its contaminated . If so you can do what Tsbservice said or order a new developer unit.
              It would also help if we knew the direction the sample is feeding
              • copyman
                Owner / Technician
                • Sep 2005
                • 4633
                As I suggested to OP outside this forum is to replace the laser. Maybe he can post on this forum if someone has one from a B&W model they want to sell. Can't remember if he changed the dev unit but would also install new unit since black developer units are a lot less $$ then color. Even if the level history is showing good #'s around 6 % I would still replace dev unit. And to put this to rest wouldn't hurt to replace the transfer roller as suggested in this thread. These 3 things will cover only things left.
