Bizhub 4052 does not print
  • cyta123
    • Aug 2015
    • 46
    I have Bizhub 4052. The machine didn,t print from a computer and any reaprts from the machine,only 4 leds blinked, as a copier worked fine. I updated firmware , the machine started working fine. But after 2 week is the same, Bizhub didn't print again, as a copier worked fine. What should I check/change?
  • Ziggy
    • Feb 2018
    • 764
    The only time I have seen the LEDs blink on the machine like its receiving data but nothing comes out is when account track is turned on and they don't have the password set in the driver.. If that is your problem you can either set the password on the driver or have the machine to print without authentication
    • Synthohol
      Certified Konica Expert
      • Mar 2016
      • 5844
      can you backup the address book and initialize at least the network portion?
      • copyman
        Owner / Technician
        • Sep 2005
        • 4713
        Just had this on a 4752 and turned out the date & time were wrong. Check the memory battery if it keeps losing the date & time.
        • cyta123
          • Aug 2015
          • 46
          There are not any account. I thought about emmcb and a battery. As copyman wrote , probably battery, because I was backup address book , files have no date of creation​ . I will let you , when I check the battery.
          • tsbservice
            Field tech
            • 8020
            I never heard that on this model good hint copyman
              • 23009
              https://www.copytechnet.com/forum/te...25#post1335825
              Sadly, yes.
              • copyman
                Owner / Technician
                • Sep 2005
                • 4713
                I've replaced several Batts on the Biz 4750 because of date and time not holding. But recently had a 4752 where it would copy fine but wouldn't scan or print after a power outage. Realized the time & date were wrong and after changing to correct time & date (thanks Synthohol) it solved issue.
                • ionutkok
                  • Nov 2012
                  • 24
                  Enter Servie Mode -> System 1 -> Initialization -> Clear All Data . Save your Store Adress, IP. After clear you need to install HDD, Movie data, IP, Store adress etc .
                  • cyta123
                    • Aug 2015
                    • 46
                    The date was 1970y. When I changed the correct date, the machine started working fine. I changed the battery, I will be watching now for some days.
                    • copyman
                      Owner / Technician
                      • Sep 2005
                      • 4713
                      Glad it worked out. You should be fine moving forward
                      • cyta123
                        • Aug 2015
                        • 46
                        So far, the machine is working properly after replaced the battery.
