C258 trouble codes D010 - D011
  • copyman
    Owner / Technician
    • Sep 2005
    • 4653
    I'm getting D011 & D010 codes which I know are for HDD plus this message popped up one time "preparing security external documents". Tried 3 different HDD's. Won't take reg or reset firmware. If HDD uninstalled it boots up and works good. Is there a "Bizhub Secure" setting to prevent HDD format? Any ideas appreciated?
    Thanks in advance
  • AlaskaCopyTech
    • Jan 2024
    • 77
    Sure sounds like bizhub secure to me. Bizhub secure encrypts the hard disk. Have you tried going into the bizhub secure settings to see if anything is turner on?
    • copyman
      Owner / Technician
      • Sep 2005
      • 4653
      I've poked around in service mode and admin mode and didn't see anything on. Is there a specific bizhub secure tab or soft switch? is it in admin or serv mode? I will check again.
      • AlaskaCopyTech
        • Jan 2024
        • 77
        You will want to get a bizhub secure guide and go through the settings it talks about enabling. Bizhub secure is scattered across admin, service and storage management.
        • Ziggy
          • Feb 2018
          • 701
          enjoy, You can do a physical format of the hard drive to remove the encryption form it. You will have to do a logical format after doing a physical format
          • copyman
            Owner / Technician
            • Sep 2005
            • 4653
            I've tried physical & logical formats on 3 different good working HDD's and none worked. Service manual shows those HDD codes could be bad MFP board.
            • Ziggy
              • Feb 2018
              • 701
              or Cables going to HDD. Also make sure the HDD is plugged into the right spot. On the 8-series it is capable of having two HDD's. If memory serves me right I think if you only have one HDD it plugs into the top data and power slots of the MFBP
              • tsbservice
                Field tech
                • 7998
                Try Overwrite All Data function.
                  • 23002
                  That was my thought. There have been very few cases (less than 3) in which the HDD did not resolve a HDD error. It was the MFPB. =^..^=
                  • copyman
                    Owner / Technician
                    • Sep 2005
                    • 4653
                    As suspected it turned out to be the MFPB.
                    https://www.copytechnet.com/forum/te...ries-mfp-board
                    All good now.
                    Thanks again
                    • Slammers
                      • Feb 2019
                      • 131
                      I know you have already swapped boards. But did you try the SATA Controller FW? There was a bulletin and service tool pack for this issue. There was a problem with those machines when they launched. The SATA controller started writing garbage to the SSD which would cause slow boot times, no address book and pretty much all the symptoms you described. If you still have the board it would be interesting to see if that was the problem. Out of my fleet I only had to perform the process on one device so was a rare occurrence.
                      • copyman
                        Owner / Technician
                        • Sep 2005
                        • 4653
                        I may put the bad MFP in the donor machine and mess with it. If still no luck was going to send to Hytec for repair.
                        • Slammers
                          • Feb 2019
                          • 131
                          Nice, could save you a repair bill.
                          Note, MY TB is from Olivetti and I am unsure if the FW package names are the same. I have used KM FW on Olivetti machines and vice versa, but you know your stuff I and am confident you should be able to work it out.
                          The TB I have was relased 27/06/2016 and you will need:
                          A7PU0Y0-F000-GXX-A8 - SATA Controller Firmware Recovery Tool
                          A7PU0Y0-F000-GXX-B0 - SATA Controller Firmware
                          Let me know if you manage to ressurect it.
                          • tsbservice
                            Field tech
                            • 7998
                            Yes they are the same on Konicas.
                            After update SATA Controller version ends in G00-04.
                            • Slammers
                              • Feb 2019
                              • 131
                              In service mode does the full controller read A7AH0Y0-6403-04?
                              Did you perform the recovery first or did you flash the new sata FW first?
                              Since your machine was already exhibiting the failure conditions(D011 and D050) you will have to run the SATA recovery tool even if the SATA FW has updated correctly to the new version.
