C658 c-3102 error, fuser drive assembly?
  • FuserNoob
    Service Mgr, CISSP
    • Jul 2022
    • 137
    Hi again everyone,
    I have a customer with a C658 displaying a C-3102 error with an associated gear/slippage sound coming from what sounds like the fuser drive assembly. I ran a load check on code-45, multi code-8, Soaking Roller Pressure Solenoid and was able to duplicate the sound.
    I remember reading something about an updated fuser drive assembly, but can't find the tech bulletin.
    Can you check my math on this before I order a $350 part?
    I need to replace the fuser drive assembly, part # A79JR71633, correct?
    Thanks again!
    • 8105
    Since the fuser unit is much easier to replace id start with that
    • kingarthur
      • 1304
      They brought out a mod for the fusers, the cleaning roller would seize, you had to install proper bearings in place of the bushings. - however, any recent fuser should already had the mod
      • Synthohol
        Certified Konica Expert
        • Mar 2016
        • 5738
        is there rust dust near the door hinge area by the fuser?
        • FuserNoob
          Service Mgr, CISSP
          • Jul 2022
          • 137
          yes, that was the first thing we tried
          • FuserNoob
            Service Mgr, CISSP
            • Jul 2022
            • 137
            you mean like this?
            • Synthohol
              • Mar 2016
              • 5738
              yup.
              replace fuser drive assy.
              and the fuser that gave it such a hard time turning.
              or remove the cleaning roller to buy some time with it.
              <- saw you did already
              /.02
              • FuserNoob
                Service Mgr, CISSP
                • Jul 2022
                • 137
                yup.
                /.02
                Thanks for checking my thinking again, Synth!!
                • SAR
                  • Jul 2009
                  • 199
                  The number for that fuser drive assy is A79JR71644.
                  • FuserNoob
                    Service Mgr, CISSP
                    • Jul 2022
                    • 137
                    That's the revised version, correct?
                    Thanks!
                    • Synthohol
                      • Mar 2016
                      • 5738
                      always wanted to try spraying white vinegar in the rusty clutch and follow with IPA after 60 min.
                      the vinegar eats rust like a demon and would likely give the clutch plates new life but i didnt want anyones office to smell like a Salad-Hut.
                      • allan
                        RTFM!!
                        • 5459
                        I just use plastic safe contact cleaning spray with the pipe attached. Water will condense inside it, make sure to get it dry as quick as possible. I do this as a preventative measure on clutches around the 400K mark.
                        Whatever
                        • SAR
                          • Jul 2009
                          • 199
                          Thanks!
                          Could not find a bulletin, but that is the updated number
                          • FuserNoob
                            Service Mgr, CISSP
                            • Jul 2022
                            • 137
                            The guy who did my initial training on copier repair swears by DeoxIT as a cure all:
                            Thanks for reminding me that I have some. I'm going to give it a shot. At this point it can't get worse
                            • Tech09
                              • Apr 2020
                              • 139
                              Pretty much all of our 8 series needed to have their fuser drives replaced at 1 million, we kept a couple rebuilt fuser drives in stock and swapped out as needed.
