Strange 3070L image issues
  • nullskull
    Learning
    • Aug 2023
    • 485
    #16
    Well the issue is coming back again. Still on the black. Very strange.
    WhatsApp Image 2025-03-31 at 16.14.49_e7832835.jpg WhatsApp Image 2025-03-31 at 16.14.49_3f5ba128.jpg
    • Ziggy
      • Feb 2018
      • 801
      #17
      did you run the initial setup on the developer? Toner Density Sensor Init
        • 23010
        #18
        How many clicks on the developing unit?
        • nullskull
          Learning
          • Aug 2023
          • 485
          #19
          Yes
          • nullskull
            Learning
            • Aug 2023
            • 485
            #20
            427,611 on page and 39/100 on time
              • 23010
              #21
              Is the current genuine toner cartridge nearly full? The previous toner cartridge may not have been genuine, and it could take some time to consume the non-genuine toner in the toner feed system.
              If you run heavy black fill images it may get worse, then better.
              • nullskull
                Learning
                • Aug 2023
                • 485
                #22
                The toner bottle was nearly empty so I replaced it with a fresh one. I've only been using original toner. However, they ordered the 619 toners on accident and once the 620 bottles got too low they just told me to transfer the 619 toners into the empty 620 bottles. They said it would be alright but now that this is showing up I wonder if that's not the case. The 619 is for the 3080P while the 620 for the 3070L. Maybe they are different enough to be causing the issue?
                  • 23010
                  #23
                  I can't say if they're the same or not. I can say that it looks like a toner issue ... especially if a developer change cleared it up until it started adding toner again
                  • nullskull
                    Learning
                    • Aug 2023
                    • 485
                    #24
                    I'll run some heavy black fill images through the machine and see if it changes.
                    • femaster
                      • May 2011
                      • 1519
                      #25
                      They use the same MSDS sheet for both toners, so I'd have to say they are likely identical.
                      • femaster
                        • May 2011
                        • 1519
                        #26
                        To add to this, a bulletin was just released that states Konica will be discontinuing both the of those toners (TN619K and TN620K) as well as the DV614K developer. They are offering a substitution for them, however. This applies to the US for sure, not sure about other countries. They are doing this in order to comply with US Environmental Regulation Prop 65. See attached bulletin for details.
                        • nullskull
                          Learning
                          • Aug 2023
                          • 485
                          #27
                          Oh thanks!
                          • Ziggy
                            • Feb 2018
                            • 801
                            #28
                            yeah they are making it with less carbon black . This is probably going to effect the black density . How much only time will tell but this isn't only going to effect KM machines, This is going to effect the entire industry . I've been told that the printing industry has lobbyist trying to fight this. not sure if they will have any luck
                            • nullskull
                              Learning
                              • Aug 2023
                              • 485
                              #29
                              So the drum was changed. The dev unit was also swapped out from a different machine. And the issue is still there. The tech that came by said he thought the dev looked overtoned.
