konica minolta c3320i wont wake up
  • brent
    • Nov 2008
    • 1214
    so out of my 40 or so machines c3320i in the field this one was fine for 5 years.. now all of the sudden it will go to sleep and then the fan runs but it won't come back on to copy
    I went out there and could not get it to go into energy save but I made it I think go to 60 minutes.. the customer then states that once they shut it off it takes a time or two (I told them about the 10 second restart ) then it comes back on and it will do the same thing all a gain.. I have the machine managent list.. anything I should look at? like I said its the only one I have that does this.. any thoughts> thank you guys
    brent
  • Ziggy
    • Feb 2018
    • 802
    disable sleep mode and update boot rom and firmware to GG3-RE. set switch 25 hex 40
    • brent
      • Nov 2008
      • 1214
      I am trying to disable the energy save its so much different then the full size i series machines. I was able to disable the power consumption in sleep mode but didnt actually
      find the s leep mode to disable any help? I wonder if I am the wrong screen
      brent
      • Synthohol
        Certified Konica Expert
        • 5892
        9.4 Sleep ON/OFF Choice Setting
        • To display the option of “No” for the [Sleep Mode Setting] screen available from [Administrator] -> [Maintenance] -> [Timer Setting] ->
        [Power Settings].
        Setting item Contents Default setting
        Permit To display “OFF” in the sleep mode setting screen.
        Prohibit No to display “OFF” in the sleep mode setting screen.
        set this to permit, then sleep mode can be turned off.
        • brent
          • Nov 2008
          • 1214
          [Power Settings].
          I must be slow today when I go into power setting in the admin screen it shows the following
          low power setting
          sleep setting
          power save settings..
          I must be dumb what one do I hit.? I d not see a prohibit maybe I can add a photo
          thanks and sorry I cant find the button
          brent
          • brent
            • Nov 2008
            • 1214
            Here is a picture of what I am dealing with thank you
            • Synthohol
              • 5892
              its in service mode, system 1
              sleep on off choice setting
              need to set that to permit first.
              then the option to turn OFF sleep mode will appear on the screen you captured.
              • brent
                • Nov 2008
                • 1214
                that makes more sense.. i will do that thank you
                brent
                • brent
                  • Nov 2008
                  • 1214
                  i DID in deed set switch 25 to hex 40 and also disabled sleep it has not shut off yet.. I am not good with firmware but just letting you know I appreciate you and every
                  ones advice maybe this fixed it
                  brent
                  • barber782
                    • Aug 2011
                    • 286
                    was this resolved in the end? I had one where it would randomly turn off and wouldn't wake up unless switching off the main switch and unplugging.
                    Already did the sleep/power adjustments as its standard practice on our machines.
                    Anyway... a new cpub fixed my issue. same on a c257i.
                    • brent
                      • Nov 2008
                      • 1214
                      NOPE I had it on and it worked for a week. thought I had it fixed. then one day it shut off.. customer bought another machine from me
                      so it sits until I can do more reserch on it.
                      brent
                      • stronghold
                        • Apr 2023
                        • 49
                        Troubleshooting ALL i-Series with problem: Sleep, Boot and Power Control.
                        LINK on CPU1, CPU2, Boot Rom Firmware Update Procedure
                        Troubleshooting Note:
                        If flashing fails for CPU1, CPU2, or Boot ROM, the issue is likely related to SPI Flash (BIOS) corruption on the CPU Board.
                        Possible Solutions:
                        1. Replace the CPU Board (recommended for most users).
                        2. Repair using a programmer (requires specialized equipment and expertise).
