KM 654 - text double image
  • aberock
    • May 2022
    • 130
    Hi guys, please refer to my photo can seen the text is print like slight delay caused it double at the same place.
    What's the issue? Already service the registration and drum unit still same.
  • Ziggy
    • Feb 2018
    • 802
    is this close to lead or trail edge?
    • aberock
      • May 2022
      • 130
      Trail edge sir
      • Synthohol
        Certified Konica Expert
        • 5895
        what happens landscape? SEF
        • aberock
          • May 2022
          • 130
          Same sir also happen at trail edge when landscape
          • Ziggy
            • Feb 2018
            • 802
            as old as this machine I wouldn't put any money in it. If you have a machine you could borrow the fuser from I would try that
            • Synthohol
              • 5895
              pic please.
              did the blurring change direction with the image or does it now go across the short edge?
              • aberock
                • May 2022
                • 130
                When print in landscape
                • Synthohol
                  • 5895
                  can you stop it before it hits the fuser at the end?
                  double check the reg roller and 2nd transfer roller too, it maybe when the trail edge is out of the last vertical transport roller the paper stalls or flicks causing 2nd transfer blur.
                  id keep stopping the process until i saw where the blur happens.
                  whats the life on the belt and drum? the gradient looks poor as it is.
                  • tsbservice
                    Field tech
                    • 8053
                    In my old Toshy days I would say developer unit spacers/rollers. I think if you can change black developer unit(DV-711K) it would narrow down this.
                    • kingarthur
                      • 1385
                      Is it a print or a copy, if a copy is it from the glass or RADF - I've seen that happen so many times on the older devices where the document feeder isn't the correct height at the back. If printing, is the image on the the transfer belt, or the drum
                      • Slammers
                        • Feb 2019
                        • 157
                        This looks like a drive issue with the paper slipping/stopping at time of second transfer. I have had this and it turned out that one of the main drive gears for transport had lost a tooth causing a skip in vertical transport past the ITB.
