Paper tray not detecting correct paper size.
  • nullskull
    Learning
    • Aug 2023
    • 396
    [Misc] Paper tray not detecting correct paper size.
    I have a 3080P here with Fiery server. Tray #1 isn't properly detecting paper sizes. For instance I'll put in letter size paper (8.5x11) and it'll say it is B5 paper. I've tried calibrating it in admin mode with the paper tray calibration. Any ideas?
  • Synthohol
    Certified Konica Expert
    • 5796
    marketing area set to metric not inch?
      • 22997
      The paper size adjustment is шn Service Mode > 01 Machine Adjustment > 06 Tray Adjustment >
      The description of the procedure starts on page 1235. Did you read this procedure? It is not intuitive. It uses some unusual paper sizes. In some of my high volume locations I cut cardboard to those sizes, and kept it stored on site to make it easier to adjust, and I've had to do it frequently.
      On my highest volume machine I've had to replace the size VR when it would not consistently read the size correctly.
      • Ziggy
        • Feb 2018
        • 692
        I have had to replace the connectors for the trays on the paper feed unit for this problem before but never on the machine. But most of my customers have air feed paper feed units so they rarely use the trays on the machine.
        • Synthohol
          • 5796
          id try this first.
          then the electronic adjustments
          • Ziggy
            • Feb 2018
            • 692
            • IF this is set to metric it will read wrong paper size
            • supplementary explanationThere is, however, a group of sizes having subtle distinctions, so that the machine cannot distinguish in the operation of size detection. Let the machine detect a specific size by identifying these sizes as any one of them.
            Press Detect Size Setting. The Detect Size Setting screen is displayed.
            Groups of indistinguishable sizes are arranged in columns. Press the desired size in each column to select it. Press OK.
            • supplementary explanationDetectable sizes may vary depending on whether ON or OFF is selected for the use of K Size in the Administrator Setting provided on the Utility Menu screen. For details, refer to K Size.
            • supplementary explanationDetectable standard sizes vary depending on the paper tray.
            • Ziggy
              • Feb 2018
              • 692
              I'll be in front of one similar Monday. I'll post better instructions
              • Ziggy
                • Feb 2018
                • 692
                Here are the steps Paper settings>Choose Tray>change set> paper size> detect size setting. set all to the inch size. Pictures attached
                • nullskull
                  Learning
                  • Aug 2023
                  • 396
                  I've ran the paper size procedure with no change. I cut some ledger to the required sizes. I also conducted the centering adjustment and i found the difference between line and center to be minimal (couple mm) Idk if i printed the right test pattern though. I've turned off K sizes and also changed all detect size settings to inches like synth mentioned. The tray is still showing 8.5x11 as B5.
                  WhatsApp Image 2025-04-15 at 12.26.53 PM.jpg WhatsApp Image 2025-04-15 at 12.20.29 PM.jpg
                  have a pic of the test pattern
                  • nullskull
                    Learning
                    • Aug 2023
                    • 396
                    How do i adjust marketing area?
                    • Synthohol
                      • 5796
                      machine newer than i have screentime on, it used to be an option.
                      your best bet is to try this to set the baseline.
                      4.3.55 Tray Size Adjustment (Tray Adjustment)
                      (1) Function
                      Adjust the size detection accuracy of each tray.
                      • Main body tray
                      • MB-506
                      • MB-508
                      • LU-202m
                      • LU-202XL
                      • LU-202XLm
                      • PF-602m
                      (2) Usage
                      Perform this adjustment when the paper size is detected wrongly.
                      (3) Procedure
                      1. "Service Mode Menu screen"
                      Press [01 Machine Adjustment].
                      Note
                      ▪ When you adjust the tray size of the LU-202m, LU-202XL, or LU-202XLm, press the tray down switch (SW100) twice, and
                      lower the up down plate to the lowest position.
                      When you adjust the tray size while the up down plate is at its upper position, accurate adjustment is not guaranteed.
                      ▪ The up down plate of the MB-506 or MB-508 does not move down on the adjustment mode.
                      When you move down the plate, exit from the adjustment mode.
                      (You can adjust the tray size of the MB-506 or MB-508 even when the up down plate is not at its lowest position.)
                      2. "Machine Adjustment Menu screen"
                      Press [06 Tray adjustment].
                      3. "Tray Adjustment Menu screen"
                      Press [01 Tray Size adjustment ].
                      4. Select (Large) of the tray that you want to adjust.
                      5. Adjust the width of the side guide of the tray that you want to adjust to 297 mm with a scale.
                      6. Press [Start].
                      7. Select (Small) of the tray that you want to adjust.
                      Note
                      ▪ For the PF-602m, LU-202m, LU-202XL, and LU-202XLm, the width of the side guide is more than 148 mm when it is reduced
                      at the maximum. Therefore, the tray (small) cannot be selected.
                      8. Adjust the width of the side guide of the tray that you want to adjust to 148 mm with a scale.
                      9. Press [Start].
                      • nullskull
                        Learning
                        • Aug 2023
                        • 396
                        (1) Function
                        • Main body tray
                        • MB-506
                        • MB-508
                        • LU-202m
                        • LU-202XL
                        • LU-202XLm
                        • PF-602m
                        (2) Usage
                        (3) Procedure
                        Note
                        6. Press [Start].
                        Note
                        9. Press [Start].
                        I've done this a few times with no success
