C659 fine lines
  • mrfuser
    • 1626
    C659 fine lines
    Fine lines just started up. Any ideas? Tried the set up again in ce mode . No change
    This gallery has 1 photos.
  • copyman
    Owner / Technician
    • Sep 2005
    • 4762
    Did you print separate test pages for each color? If lines only when you print magenta test page I would look at magenta image unit as issue.
    FYI, when machine needs to be setup again there will be blue lines evenly spaced apart. They are called "blue lines of shame"
    • KMFLT3CH
      • May 2017
      • 242
      Magenta IU going bad, open the front door and pull it out, should be somewhat obvious looking at the drum.
      • mrfuser
        • 1626
        That’s just the thing all the imaging units looked perfect and the customer said they started right after they got a jam now that a jam
        Now that they told the truth
        • Ziggy
          • Feb 2018
          • 801
          swap yellow and magenta drum and see if symptoms change
          • aberock
            • May 2022
            • 129
            service the IU unit . the charging
            • tsbservice
              Field tech
              • 8052
              M drum PCR.
              • copier tech
                • 8200
                You can't swap the image units around on the C659.
                • mrfuser
                  • 1626
                  Turned out the lines were on the charge roller. No idea why they appeared suddenly but cleaned the roller and all things related and replaced drum and back in business!
                  • JasonSBE
                    • Apr 2014
                    • 187
                    Glad it's working, but the lines will most likely come back. Once there are grooves in that charge roller, toner is going to find its way back into them. Be prepared to change the IU in the near future.
