C360i black screen
  • Boyaka1989
    • Mar 2021
    • 19
    [Dead] C360i black screen
    hi im dealing with a isseu here where i updated the machine c360i bootrom after the restart the machine screen does not turn on but i do hear the machine startup and adjust .
    have no idea why ramdomly it does not disply anything not even the red or bleu lights please help.
  • occus
    • 337
    Tryed load firmare again?
    • femaster
      • May 2011
      • 1506
      Make sure the USB-C cable that comes from the diplay panel is firmly inserted in it's jack at the very top under the port access cover on right side of the copier. See Item #1 in the attached picture.
      • Boyaka1989
        • Mar 2021
        • 19
        tried it then the machine does even bootup dont hear or see anthing.
        • Boyaka1989
          • Mar 2021
          • 19
          yes this was checked im about to even test a differnt display on it to see if it will react .
          • Black Cloud
            • 163
            Failed bootrom with black screen requires a repartition of the storage board, or a new storage board. I've seen this twice.
            Net+ PDI+ @Remote
            • Boyaka1989
              • Mar 2021
              • 19
              thank u for the response how can i fix this?
              • doinbox
                • Jan 2013
                • 109
                Take out the Storage Board, Put it in a usb drive caddy and delete all partitions
                • kingarthur
                  • 1363
                  I've just had a C300i with a "black" screen, before it happened, I was getting constant D313 errors, it ended up being the CPU board
                  • Jumping Jack Flash
                    • Jul 2009
                    • 66
                    I can recommend a service that repairs CPU-B modules for the "i" series for KM. Since most CPU-B module failures are hardware-related,
                    software tools provided by the manufacturer will not always help.
                    • Boyaka1989
                      • Mar 2021
                      • 19
                      thanks is there a guide or bulletin that can help me with this?
                      • Tech09
                        • Apr 2020
                        • 145
                        Troubleshooting Bulletin
