i-Series CPU Board (CPUB) Issues: Diagnosis and Repair Solution
  • stronghold
    • Apr 2023
    • 38
    Originally posted by copytechtrouble
    can you elaborate a bit more on these two points please?
    To my great regret, I can't explain here how exactly it's done because this information isn't publicly available. Konica Minolta insists that the board must be replaced—so technically, that's what you're supposed to do.
    I don’t mean to sound tactless, but if you turn to Google, you can find all the necessary information if you spend some time searching.
    I’ll help you with that!
    First, study what an SPI Flash is and what it looks like.
    • tsbservice
      Field tech
      • 7973
      Understandable. I don't think you are asking too much when KM changes 500$ for CPUB or Storage board and someone spent countless hours studying and finding resolutions asked a fraction of big corporation prices for that labour. It's fair price for time and knowledge at least to me.
      Thanks stronghold
      • adecanmin
        • Oct 2010
        • 291
        So it looks as though we can purchase a 128GB Kingston Canvas microSD Class10 UHS-I U3 (V30) and flash it with the appropriate firmware and the machine will work. I turn off the sleep mode. Looks like a bunch more work to that function to work properly.
        • kingarthur
          • 1325
          #19
          Thanks for sharing your experience with that much details. So based on your findings do you think we should start updating CPU1, CPU2 and BootRom on all devices as routine?
          Just out of interest, I thought I'd try updating CPU1, CPU2 and Bootrom. I'm lucky that I have a couple of scrap devices that I can play around with. CPU1 updated and restarted ok, CPU2 updated....and just keeps rebooting.....
          • tsbservice
            Field tech
            • 7973
            #20
            Thank you for that I know why you're posting it.
            Let me say we did updated power control CPU2 firmware many times as well with boot rom as precaution to C5372.
            Never bricked something... knock on wood I know but I never hesitate to jump on new solutions
            But if CPU board is already corrupt for example SPI flash is bad then CPU2 update may goes wrong way as per your experience and stronghold mentioned also the same.
            It's interesting topic and good that many techs may contribute here.
            • Slammers
              • Feb 2019
              • 116
              #21
              Can confirm we experienced the same symptom last week. FW, CPU1 worked fine, CPU2 updated then it was stuck in a boot loop. Wouldnt recognise USB, removing the NVMe made no difference.
              Had to swap the CPU-B to resurrect the machine.
              • occus
                • 331
                #22
                Okay, what's recommended now? Should I update or not? I don't want to spend my money repairing contract machines that might have to last another 1-2 years.
                I haven't had a single overheating incident so far.
                Thanks for your opinions.
                • Slammers
                  • Feb 2019
                  • 116
                  #23
                  That is a good question and I can't really advise as it all depends on your own environment and fleet.
                  In my fleet, this was the only machine that has ever needed a new CPU-B and it was due to me poking at it with the CPU FW, so take that information as you wish....
                  Bear in mind, that there are separate SW Switches you can set that will adjust the CPU fan behavior. These do not require messing with the BOOT/CPU1/CPU2, just make sure you are on the latest FW available.
                  From what I have seen the CPU/BOOT updates were mostly to do with issues with the NVMes and the Boot Diagnosis bulletin if your machine was unresponsive. I think my course of action will be to ensure that my machines are on GC2-RF and then I will modify the following SW Switches for CPU fan adjustments:
                  With the lastest GC2 RF you can set SW 159 to 0 (FAN OFF) THEN set 187 to hex 40 to spin it at half speed. Full details are in the FW bulletin included in the FW release.
                  If you just set 159 to BIT 7 the fan runs at 100% all the time - this is loud but may be OK in a factory environment if you need more cooling. You have to make sure that 187 is 0 if wanting it at 100% - from here:
                  2. C5372 (CPU temperature failure) occurs during the low power or the sleep mode.
                  As a countermeasure, please change software SW to work the FAN at half speed during Low Power and Sleep mode after applying this firmware.
                  A function to work the CPU FAN at half speed during low power and sleep mode.
                  Software SW No. 187 (bit6)
                  Hex: 00 (Disable [default]) FAN stops in low power/sleep mode.
                  Hex: 40 (Enable) FAN works at half speed in low power/sleep mode.
                  When using this function, the following software SW must be disabled
                  A function to work the CPU FAN at full speed during low power and sleep mode.
                  Software SW No. 159 (bit7)
                  Disable : FAN stops in low power/sleep mode.
                  Enable : FAN works at full speed in low power/sleep mode.
                  • KMFLT3CH
                    • May 2017
                    • 226
                    #24
                    If it ain't broke, don't fix it.
                    • tsbservice
                      Field tech
                      • 7973
                      #25
                      As I already said we did many updates with special firmware. It always does bootrom at first and then CPU2 updates and we never bricked CPUB in such way. We did it because KM said so plus some other measures like running cpu fan half/full speed in sleep mode to prevent CPub overheating. Prevention is key.
                      • Slammers
                        • Feb 2019
                        • 116
                        #26
                        100%. I do Kyocera and they won't even speak to you about a machine unless you've updated everything to latest.
                        I was just adding my experience for Kingarthur as we have seen the same thing. Working machine - >Update CPU2 - > Dead Machine
                        • femaster
                          • May 2011
                          • 1482
                          #27
                          The attached, recently released, Tech Bulletin from KM US sounds like it should answer some questions for those that are having problems.
                          It doesn't mention anything about a CPU1 update as some have commented about, only a CPU2 update. Perhaps CPU1 is in the EU only? We also do not have anything in the firmware download area that contains any CPU1 updates.
                          In any case, it states to NOT update the CPU2 unless you are receiving the overheat service code. It also states that depending on your current level of firmware, you have to do the update in a certain order or you risk bricking your CPUB resulting in a no boot situation requiring the replacement of the CPUB.
                          We've never had any overheat issues with any of the A3 model machines, but have had a few of the A4s. As of right now, we do not update that A3 machine with the CPU2 update, but do update all our A4 machines. It's not worth the risk for us to have to replace a CPUB in one of tiny piles of crap, so it's done as a preventive measure to makes sure there aren't any problems with them.
                          • Slammers
                            • Feb 2019
                            • 116
                            #28
                            Interesting read.
                            The CPU1 -> CPU2 -> Boot ROM installation order that I have came from one of the SSD Recovery / No Boot Up bulletins, nothing to do with CPU Overheat.
                            For me, I am not touching the CPU1 or CPU2 updates unelss I get any CPU overheat related codes.
                            Hopefully the fan speed SW in low power mode is enough to prevent any issues which only requries the FW.
                            Thank you for that info, have added it to the long list of quirky iSeries documentation.
