C308 SMB Win11
  • cayyell
    • Feb 2013
    • 85
    C308 SMB Win11
    I feel like crying right now.
    I have an office, upgraded from C280 to C308. But I am having intermittentissue on SMB scan right now. For some reason it will fail on the C308 randomly. Is there anything else I need to take note or change in the DipSw?
    I belive the firmware is A7PU0Y0-0100-GC2-R9.
    Been so many years, we were fine with the C308, happen that SMB2.0 is supported out of the box. But I cannot pin point how come it will fail randomly
  • Black Cloud
    • 176
    Released a few weeks ago... G00-Y8 firmware. It adds TLS v1.3 capability to that machine.
    Net+ PDI+ @Remote
    • JMS
      • Apr 2023
      • 30
      Do you scan to Hostname or IP-Address?
      Do you use DHCP for the scan-target?
      Is it public or private network?
      Is the scan-target wired or wireless connected? Or does that sometimes change?
      • doinbox
        • Jan 2013
        • 120
        Antivirus?
        • cayyell
          • Feb 2013
          • 85
          Hostname,
          do you mean the target PC is DHCP or not? Tried both, static and DHCP, seems to be the same. But often time when I check, it works. However, in the history, I did see the failed scan jobs.
          Tried both ways, user reported fail. I mean I did set it to work on both private and publlic
          The reported failed users are wired PC
          Does TLS v1.3 helps on SMB scan? I thought that it only affects emails.
          Antivirus?
          It is a end-point antivirus. Since another C280 on site works, I cant see how that endpoint would render the scan on C308 failed.
          • doinbox
            • Jan 2013
            • 120
            Hostname,
            Antivirus?
            Personally I think your best option would be to update the firmware to at least X or Y
            • JMS
              • Apr 2023
              • 30
              TLS is for E-Mail.
              Do they still use C280? Then could the SMB-Configuration be a problem (C280 can only use NTLMv1 / SMBv1)
              • doinbox
                • Jan 2013
                • 120
                Just to add to this I've had a look through most of the firmware updates notes in between your GC2-R9 up to the latest Y and there are so many SMB fixes. Not necessarily what you're explaining but enough to make me think your intermittent scan issue may be resolved with the latest firmware applied
                • Ziggy
                  • Feb 2018
                  • 802
                  Set it to scan to IP that will last until the lease of the IP expires and if the PC pulls a different IP
                  • JMS
                    • Apr 2023
                    • 30
                    13. Scan to SMB fails sporadically when using SMBv1
                    Found in the release notes for FW GC2-X4 Function-Version 4.2
                    • Synthohol
                      Certified Konica Expert
                      • 5892
                      make sure the time and date on the copier is accurate, i know email fails if the server time and copier time differ. not sure if SMB does the same.
                      • cayyell
                        • Feb 2013
                        • 85
                        Thanks, I would just do that. wondering if any kind soul, want sell me one or dm me?
                        • Ziggy
                          • Feb 2018
                          • 802
                          DM or give me your email here
                          • Ziggy
                            • Feb 2018
                            • 802
                            GC2-X4 is no longer listed on the KM site in the U.S. But I have it or could send you the latest base firmware is G00-YB posted 06/19/2025 or the lates special posted on 06/26/2025. Just let me know which firmware you want
                            • llzzll
                              • Jun 2023
                              • 16
                              I had it on a maschine for some days too. It needed a new update ands TLS 1.3 was ready
