Trouble code c0204 on km c250i
  • Esron Thomas
    Service Technician
    • Oct 2024
    • 65
    Hi guys I've got a Trouble Code C0204 on konica minolta bh c250i, I tried check for paper jammed, and debris, but nothing, tried power cycle, trouble reset, and system error clear but still trouble code c0204 exist, any idea?
  • Brad6784
    • Mar 2015
    • 84
    Hi, this is an error to do with the tray lifting motor, it’s usually paper trapped behind the paper tray, causing the tray not to rise. Obviously it could be caused by the motor or sensor but I would start by removing the tray and checking for paper. I believe that code is tray 2 but I would check behind all trays, if there is no paper I would then remove the complete pickup unit and investigate further. Good luck!
    • tsbservice
      Field tech
      • 8064
      Lol... system error clear for one piece of paper trapped
      • Esron Thomas
        Service Technician
        • Oct 2024
        • 65
        I've tried that, remove all the trays check but no paper stuck inside the sensor and the pick up unit looks perfectly fine, but the trouble code still exist
        • Esron Thomas
          Service Technician
          • Oct 2024
          • 65
          I physically checked but no piece of paper before doing system error clear..
          • Synthohol
            Certified Konica Expert
            • 5905
            likely an actuator stuck?
            • Esron Thomas
              Service Technician
              • Oct 2024
              • 65
              Thank you I'll try that out and keep you updated
              • copyman
                Owner / Technician
                • Sep 2005
                • 4785
                I would have tried the sys error clear as well if no paper stuck. Did you test sensors for tray 2 in service mode?
                • Esron Thomas
                  Service Technician
                  • Oct 2024
                  • 65
                  No I didn't because did remote assistance with the customer via WhatsApp video call and I just told to check and clean the sensor (PS22) I guess?
                  • JasonSBE
                    • Apr 2014
                    • 187
                    Did you hit continue, confirm that you wanted to disable the cassette, turn the sub power off then on, then reboot the mfp?
                    • JMS
                      • Apr 2023
                      • 30
                      Sounds simple, but have you open and closed the frontdoor without turning machine off and on? Rank B is reset by that.
                      • Esron Thomas
                        Service Technician
                        • Oct 2024
                        • 65
                        We tried that several times but trouble code re-appears straight after the door closure
                        • Esron Thomas
                          Service Technician
                          • Oct 2024
                          • 65
                          I tried that by isolating the tray 2 and the trouble code cleared, so I need your advice what is the real issue is, is it the PS22 or M13 faulty or other thing
                          • copyman
                            Owner / Technician
                            • Sep 2005
                            • 4785
                            Not much more to offer here for what the "real issue" could me. You have been given some good detailed advice to work with. You will need to troubleshoot the things mentioned above, i.e. checking sensors, lift motors in service mode. If you don't have a service manual I suggest you get one. Best of luck
                            • stronghold
                              • Apr 2023
                              • 49
                              I usually test MFUs in the following order:
                              Step 1. Take a working sensor from tray 1 and install it in tray 2.
                              • If the issue moves to tray 1, then...
                              • If everything stays the same, proceed to Step 2.
                              (You can check its functionality from the Service Menu under "Sensor Check." Open position = 0, closed position = 1. I think that’s how it works. In this mode, you can see whether the sensor responds when the tray is closed or lifted.)
                              This is what my working sensors look like when the second tray is closed (with no paper loaded):
                              Step 2. Take a working lift motor from tray 1 and install it in tray 2 .
                              • If nothing changes, move on to Step 3 ))
                              Step 3. Check the wires connected to the sensor and the motor.
                              PS. Make sure the paper lift mechanism (inside the tray itself) is functioning properly.
                              PPS. If none of the above helps, move on to the CPU board (CPUB) and software-related troubleshooting.
                              Beyond this, I don’t know how else to assist with your diagnostics. I think many engineers would agree with me.
