C360i Booting up at 50% forever
  • Esron Thomas
    Service Technician
    • Oct 2024
    • 59
    #31
    Originally posted by plus-COPY
    Everything is very simple, provided you determine what is damaged. Dismantle the SSD, use a clean 16/32GB SD card and install the firmware, we'll see what the result is. I don't understand why you want to replace both components at the same time, but the procedure is the same.
    Hiplus-COPY
    In my case I don't have ssd installed on the printer, how do I determine the other faulty components if the screen boot up at 50 % and can't load the normal screen? In the service manual it suggests we replace the cpub and strgb.
    • plus-COPY
      • Aug 2023
      • 33
      #32
      Originally posted by Esron Thomas
      Hiplus-COPY
      1. The device won't boot without an SSD or SD card that hasn't been partitioned.
      2. You can create/repair partitions by flashing the firmware to the new SSD/SD card.
      3. Without the SSD/SD card installed, you can check if the firmware update window starts and, if necessary, flash (update) the Boot ROM on CPU-B to support the SSD.
      Please describe what happens when you try to flash the firmware without an SSD or SD card installed.
      • Esron Thomas
        Service Technician
        • Oct 2024
        • 59
        #33
        Thank you that you said, I will give you the details
        At first the printer has freezing issues, I went update the firmware, download completed but when it reboot it stalled at 50 percent and stays there for ever, I checked and confirmed it has no ssd installed, I think it has SD card installed instead.
        • tsbservice
          Field tech
          • 8043
          #34
          Did you tried with another SD card?
          • plus-COPY
            • Aug 2023
            • 33
            #35
            Just to be sure, I will ask if you understand that the device must have an SSD or SD for proper operation? The SD card is not an additional option and has no function other than to boot the device correctly, the use of the SD card only restricts the use of the box and licence.
            If you remove the SSD and install a correctly formatted SD card and upload the Firmware then you will determine what is causing the device to stay at 50% of post. Try this solution and we will know what you are struggling with
            Sorry,
            Now I understand the situation more precisely. Assuming that the device was previously working on an SD card and started to hang then a test on a new different SD card will confirm/indicate what is the cause of the device not booting.
            • Ziggy
              • Feb 2018
              • 799
              #36
              If I were to replace both storage board and cpu board, do I need any specific steps or it's just plug and play Markksstronghold any ideas?
              anytime you put in a cpub you will need to make sure the machine and type is correct. this can be found in the service manual under the replacement of the cpub. But if you do replace the cpub and storage board at the same time you will lose all meters plus the consumable counts and the machine will have to be setup from scratch. Its very rare to have to replace both at the same time but sometimes you have to .
              • Ziggy
                • Feb 2018
                • 799
                #37
                Here's my email, thomasesron81@gmail.com
                firmware sent
                • Esron Thomas
                  Service Technician
                  • Oct 2024
                  • 59
                  #38
                  Originally posted by Ziggy
                  firmware sent
                  Thank you well received.
                  • Esron Thomas
                    Service Technician
                    • Oct 2024
                    • 59
                    #39
                    No I didn't I am planning to replace the cpub first and see if it solve the problem
                    • Esron Thomas
                      Service Technician
                      • Oct 2024
                      • 59
                      #40
                      I will try replace the cpub first and see if it solve the problem. I will give you update after the cpub replacement.
                      • Ziggy
                        • Feb 2018
                        • 799
                        #41
                        After you replace the cpub set machine and type turn off . then boot back in to firmware, update boot rom, turn off. Boot in to firmware update firmware to the latest.
                        • Esron Thomas
                          Service Technician
                          • Oct 2024
                          • 59
                          #42
                          Thanks mate this is the exact details I needed, now I'll go straight to replace the cpub with steps given, I have a km 450i with the same issue, so I'll start off with one first and give you the feedback later.
                          Thank you again Markks for the details.
                          • Esron Thomas
                            Service Technician
                            • Oct 2024
                            • 59
                            #43
                            Hi guys, Thank you all for your support, I managed to fix the issue by replacing the cpub. Unfortunately the meter readings were gone. Otherwise the printer is working fine now starting of with 0 meter reading
