Hi guys I'm having a problem with updating a firmware on a biz hub 363 when I update give me error of completed but says checksum 100C, check sum EE28
Bizhub 363 firmware update problem
Looking at the error code in the manual , I would try reloading firmware making sure you have the correct firmware
3.15.8 CC164
(1) Contents
Trouble type ROM contents error (MSC)
Trouble code CC164
Rank C
Detection timing The wrong model of firmware is detected in the MFP board when the main power switch is turned ON.
Trouble isolation -
Relevant electrical parts • MFP board (MFPB)
(2) Procedure
Step Action Control signal Location of electrical components
1 Check the ROM version. - -
2 Rewrite the firmware. - -
3 Change MFPB - -
4 When not reviving even if the above-mentioned procedure is
done, contact the responsible people of KM. -Comment
um, why is there nothing for the MFP board on the screen?
i dont think you selected all.
that would explain the code.
not sure if we have the whole story.
The medication helps though...👍 3Comment
