Bizhub 363 firmware update problem
  • Luis
    • Aug 2017
    • 18
    Hi guys I'm having a problem with updating a firmware on a biz hub 363 when I update give me error of completed but says checksum 100C, check sum EE28
    This gallery has 2 photos.
  • copyman
    Owner / Technician
    • Sep 2005
    • 4712
    That's not an error. It's suppose to show you "check sum" when firmware is done downloading. Looks all good to me.
    • Luis
      • Aug 2017
      • 18
      But when I switch on the machine gives me C164
      • Synthohol
        Certified Konica Expert
        • Mar 2016
        • 5842
        cc164?
        • Ziggy
          • Feb 2018
          • 763
          Looking at the error code in the manual , I would try reloading firmware making sure you have the correct firmware
          3.15.8 CC164
          (1) Contents
          Trouble type ROM contents error (MSC)
          Trouble code CC164
          Rank C
          Detection timing The wrong model of firmware is detected in the MFP board when the main power switch is turned ON.
          Trouble isolation -
          Relevant electrical parts • MFP board (MFPB)
          (2) Procedure
          Step Action Control signal Location of electrical components
          1 Check the ROM version. - -
          2 Rewrite the firmware. - -
          3 Change MFPB - -
          4 When not reviving even if the above-mentioned procedure is
          done, contact the responsible people of KM. -
          • Synthohol
            • Mar 2016
            • 5842
            um, why is there nothing for the MFP board on the screen?
            i dont think you selected all.
            that would explain the code.
            not sure if we have the whole story.
            • Ziggy
              • Feb 2018
              • 763
              Good catch , I didn't look that close at his pics. either he deselected mfpb, has bad firmware load or a bad MFPB
              • copyman
                Owner / Technician
                • Sep 2005
                • 4712
                You didn't mention anything about a C164 code on your OP? There are some damn good techs on this forum but none are mind readers. Best of luck
