Hello, machine says replenish paper after one copy at tray1. I changed casette feed unit motor unit both boards and nothing changes. Any suggestions?
Bizhub 421 says replenish paper after one copy
try pushing the tray in during a multicopy, check the tray full actuator & ps in the assy. #30
30.jpgTip for the day; Treat every problem as your dog would.....If you cant eat it or f*ck it....then p*ss on it & walk away...👍 1Comment
HA! i plastic-welded so many cracked trays in the day. soldering iron and a cd jewel case fragment for support.
for the others that needed a shim in the back for the arm id drill a hole and thread a zip-tie through it to "extend" the tray and push the arm in better. shims fall off
thats why i first suggested pushing the tray in for multipages!We know a thing or two because we've seen a thing or two.
The medication helps though...👍 2Comment
Ha-ha, some here are showing their age knowing what a Biz 421 is ...... Including me! I still have one of these in service. This customer had it since new. Only one time replaced drum , dev, PF rollers. Oh yea the toner btl assembly which was a common problem.Comment
Our last 421 "came out of the field" about 9 months ago. They just wouldn't get rid of it, and I guess I know why now. They ended up getting bought out by a Private Equity Firm, and then they filed for bankruptcy shortly after that. That was the end of that machine (and a number of other models) thankfully.A Ricoh Service Tech for 7 year. A Konica Minolta Service Tech for 7 years. Now, KM service manager for 4 years.
My Ricoh knowledge is slowly dwindling away at this point. Many things have been lost to time...Comment
Our last 421 "came out of the field" about 9 months ago. They just wouldn't get rid of it, and I guess I know why now. They ended up getting bought out by a Private Equity Firm, and then they filed for bankruptcy shortly after that. That was the end of that machine (and a number of other models) thankfully.Comment
totally off topic but Copyman reminded me of a time long ago that when certain customers were really late on payments id do a courtesy call and unplug the fuser, get a C500 error a restart wont fix so the machine is dead and needs "parts" we required them to satisfy their debt before ordering parts. worked 8\10 times.We know a thing or two because we've seen a thing or two.
totally off topic but Copyman reminded me of a time long ago that when certain customers were really late on payments id do a courtesy call and unplug the fuser, get a C500 error a restart wont fix so the machine is dead and needs "parts" we required them to satisfy their debt before ordering parts. worked 8\10 times.Tip for the day; Treat every problem as your dog would.....If you cant eat it or f*ck it....then p*ss on it & walk away...👍 2Comment
😂 2Comment
ha ha, reminds me of when I was showing the apprentice how to swap over a DV unit, i told him how easy he had it, where he just had to swap it over, years ago we had to rebuild them, and use a feeler gauge to adjust the doctor blade...."what's a feeler gauge?" he askedTip for the day; Treat every problem as your dog would.....If you cant eat it or f*ck it....then p*ss on it & walk away...Comment
