S7 Firmware PDF and File
  • AlaskaCopyTech
    • Jan 2024
    • 83
    Does anyone have the pdf or s7 firmware file? Thanks all.
  • tsbservice
    Field tech
    • 8082
    Don't do it.
    • Black Cloud
      • 182
      You'll be sorry.
      Net+ PDI+ @Remote
      • AlaskaCopyTech
        • Jan 2024
        • 83
        It's that bad? Wow-sers. Anyway I was planning on just testing it on one of my machines at the shop but it sounds best to just stay away with a 9 1/2 foot pole. Does the pdf mention any worthwhile fixes?
        • copier tech
          • 8237
          Here's the Euro release notes.
          With the new S7 firmware KM are now forcing an admin password change. As we know if been the same default for many years, I guess that's the reason for the change.
          Mass-Production Program (G00-S7 MSG96) for KONICA MINOLTA Bizhub C650i - C651i Series.pdf
          • tsbservice
            Field tech
            • 8082
            It's new RED-compliant firmware (FW) is developed in accordance with the Radio Equipment Directive (RED).
            As of 01.08.2025, all devices placed on the market without this new FW are considered non-compliant.
            Machines running the RED compliant firmware will among other changes require a non-default admin password. After an update to the
            new FW the admin password needs to be changed to a new one.​
            • copyman
              Owner / Technician
              • Sep 2005
              • 4789
              Don't see it on US dealer site. Latest is still "RE"
              • 4Toon
                • Mar 2023
                • 115
                We had some 850i come in with S7 in the USA. We had to downgrade them to special firmware for Papercut. As a warning, if you do this, it will give you a storage lock message after a restart. If you have to downgrade like us, make sure you go into Enhanced security and do the Password Decrypt first before going down in Firmware from S7. If you do not decrypt first, you will have to do the procedure of reforming the SSD memory. Also, SW 176 will be set to 1C default before S7 is 18.
                Permanently banned from Konica SSD.
